Question about Casablanca Fan Bel Air Halo Brushed Nickel Ceiling
Blade holder rubs on light diffuser
The vertical axis of the fan body is not exactly at right angle to the plane of the blades. Consequently the rotating blade holder rubs slightly on the glass cover on the bottom of the fan body. I can move the blade holder back into the proper position, but it will not stay. Any suggestions? Thank you.
3 Suggested Answers
ZTedster
  • 5 Answers
SOURCE: Scraping sound inside casablanca stealth fan
You need a new flywheel. Go here: http://www.bostonplus.com/parts.html#flywheel
Posted on Jun 19, 2009
  • 57 Answers
SOURCE: Casablanca stealth fan light scrapes against blade surround
There are two probable causes. One, the light housing has been pushed/bent up into the rotating assembly, which is possible if the fan were ever removed from the ceiling and sat on the glass.
If it has never been removed however, the most likely cause is that the Allen Set screw on the flywheel has loosened allowing the flywheel to slip down the motor shaft. It's a purely mechanical problem and if memory serves, to get to the flywheel, you remove the light pan and it's right there. Find the set screw, loosen it enough so that the flywheel is easy to move up and down and raise it up a bit and then cinch it down tight. It's a fairly common problem and for the life of me I cannot understand why Casablanca would not use loctite on that set screw. I mean you pay $500+ for a fan, it should outlast you, right?
Posted on Jun 10, 2010
How will I determine the radius of gyration using bifilar suspension?
https://www.scribd.com/doc/109721558/Bifilar-Suspension
THEORY OF MACHINES AND MECHANISNMS I LAB MANUALEXPERIMENT NO. 2 TITLE : RADIUS OF GYRATION BY BIFILAR SUSPENSION METHOD
AIM:
To determine the radius of gyration of given bar using bifilar suspensionmethod.
APPARATUSUSED:
Uniform steel bar, cylindrical weights, stop watch.
DESCRIPTION
Fig 1 shows the general arrangement for carrying out experiment. A
SET UP
uniform rectangular section bar is suspended from support frame by twoparallel cords.
Two small chucks fitted in the frame and other endssecured in bifilar bar. Ends of these cords pass through a chuck so as tofacilitate for change in length of the cord it is possible to adjust length of chord by loosening the chuck.The suspension may also be used to determine radius of gyrationof any body,In this case the body under investigation is bolted to thecenter. Radius of gyration of combined bar and body is then determined.
PROCEDURE
1) Suspend the bar from chuck and adjust length of chord ' L' convenientlynote the suspension length of each cord must be same.2) Allow the bar to oscillate about the vertical axis passing through center of gravity and measure periodic time 'T' by knowing time for 20oscillations.3) Repeat the experiment by mounting the weights one equal distancefrom the center.
THEORY
Consider bar AB whose moment of inertia is to be determine issuspended by two parallel strings as shown in figure 2.Let, L = length of each string.m = mass of bar.K = radius of gyration about the vertical axis through G.I = mass moment of inertia about the vertical axis through G.2r = distance between two stringsT = tension in each string
= angle of twist of bar.
= angle of twist of string
= angular accelaration of the bar.Initial position of bar is AGB. Now, if bar is set gently in vibration inhorizontal plane, it will start oscillating about vertical axis through its masscenter G. when bar is twisted about its C.G, through an angle
, bar is inposition A'GB' as shown. When bar is getting
as angular displacement,then string is getting
as angular displacement about vertical, distancemoved by point A is arc AA'
arc AA' = r
=L
= r
L
( 1)PIMPRI CHINCHWAD COLLEGE OF ENGG. MECHANICAL ENGG DEPT
Feb 25, 2018 | Homework
Where can I get a blade holder for a 52" fan?
  1. Fan Blade Holder - beso.com‎
    Adfans.beso.com/‎Electronics
  2. Health & Beauty Supplies
  3. Collections
  4. Brands & Stores
Search Results
    Ceiling Fan Blade Holders ' eBay
    www.ebay.com/bhp/ceiling-fan-blade-holders
    eBayThis is a ceiling fan blade arm (blade holder) from a Casablanca Ceiling Fan Company Airflow La Verne 52" ceiling fan model 1050-9. It is in good, working ...
    Fan Blades & Arms - Home Depot
Dec 29, 2015 | Dryers
How do I get the blade on my new Black and Decker 15 amp table saw to be at 90 degrees? I have the angle device at the zero mark and the blade is still at a slight angle. Is there any adjustment tha
I had a similar problem with my Ryobi table saw. I got out my square to establish true vertical, then tapped the motor housing lightly with a rubber mallet until the blade was at true vertical.
(sometime a hammer is the appropriate tool.....)
Oct 10, 2014 | Black & Decker BDTS200 15-Amp Table Saw...
How do i assemble a stanley block plainer
1, Lay pencil on the table top, place body of plane with the front (toe) resting on the pencil, so the light passes beneath the front and middle of the plnes body.
2, lay blade, bevel side up, in to body of plane, ideally sharp end is sticking out of the mouth ever so slightly., 1/2-1mm.
3, Release the knob or lever cam on the lever cap and place on top of blade.
4, tighten knob/turn leaver till it tightens on the blade. and your ready.
5, If the blade isn't protruding the mouth correctly then:
6, Loosen a knob/lever a little to allow the blade to just move, adjust the blade forwards/sidways, lock it in place by re tighten the knob/lever.
Plane a thin piece of wood, re adjust as necessary till wafer thin shavings collect in the mouth ontop of the bevel.
Aug 29, 2014 | Bailey Stanley 12-920 - Block Plane
Need a 42" white ceiling fan blade
I would need to know what fan ( make/model) you have. Is the blade broken or the blade holder?
Apr 12, 2013 | Dryers
Extension pole sways back and forth while the fan is on
One or more blades is out of line. Get a ruler or a stick and mark the distance from the tip of one blade to the ceiling. Hold the stick in place and carefully rotate the fan until the next blade is near the stick. Do this until you have all four marks on the stick. It is important to try not to alter the position of the extension pole in between blades. Now you will find that one or more blades are at different heights. Carefully bend the worst blade until it is closer to the rest. If teh blade holders are cast, this may not be possible and you may have to pack the blade angle with washers or cardboard until they are right.
If by some chance they are all close, then it may be the "attack angle" of one blade. This is harder tot detect but sometime you can pick which balde by eye and adjust by trial and error until it is better.
Cheers,
Glenn.
Nov 07, 2010 | Hampton Bay 24750 Huntington III Ceiling...
This question is for the oster golden a5 1 speed. the blade holder does not come down far enough which leaves the blade to high of an angle for it to perform properly.
sounds like the brass inserts have pulled away from the body housing of the clippers (these are where the hinge screws are located into the body) if they are pulling out you require a new body available at www.angliaclipperservices.com .
Jul 14, 2010 | Oster Golden A5 2-Speed Universal Motor...
I took the blade off of my riding mower and didn't note the original position of the blades. How do I find the correct position for the replacement blades?
Dont know exactly what you mean, but turn blades with cutting angle up. Make sure if a star like center on blade is lined up and goes over the star like on shaft and tightned bolts. If it has a tray like blade holder, just put up against it and tightned bolt. The way to remember is to put the cutting edge angled side up.
Jun 26, 2010 | Garden
The fun does not move the air
Hello acaprotta96,
If you are concerned about the angle of the fan blades not positioned to move air, you can add washers to change that angle but you will need to do that to all the blades. The blades should be balanced to eliminate wobble. If I were you though, I would contact the manufacturer and state your problem and see if they offer replacement blade supports with a more aggressive angle. As for breaking the motor... highly unlikely. especially if you are installing an even distribution of washers to balance things..
Regards,
Rick
Nov 24, 2008 | Hampton Bay 24002 Ceiling Fan
Noisey fan
In my case noise was coming from the plastic blade rubbing against the sheet metal housing. I removed the motor and added 2 washers to the mounting screws. The washers acted as spacers and lifted up the motor/blade assembly with respect to the sheet metal housing. The blade no longer rubbed against the housing and the noise stopped.
Dec 08, 2007 | Broan-NuTone N-8664RP Combination Light...
Casablanca Fan Bel Air Halo Brushed Nickel Ceiling Logo
55 people viewed this question
Top Casablanca Fan Dryers Experts
Jerry Greenberg
Jerry Greenberg
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
