Question about Craftsman Drills
Craftsman cordless drill won't work even after charging battery.
  • creatch829 Jul 18, 2009
    I was able to get it to work using another battery. The first was just shot.
    President:
  • 1,273 Answers
Try working the switches Low/High, Forward/Reverse. Sometimes, the battrey can hang up a bit in the charger, resulting in a low, or no charge. Try a different battery, or recharge your existing battery, making sure that it is firmly seated in the charger.
Regards, --W/D--
Posted on Jul 18, 2009
Where is the battery in 8 volt cordless drill
Did you give enough time to it to get fully charged before tring to work? It needs time.
Mar 02, 2015 | Craftsman 192 Volt Cordless DrillDriver...
No power on a fully charged batery why?
Users have reported problems with the charger and battery life on this drill. If possible verify the charger is working by swapping it with another or using a voltmeter on the plug.
If it is, the battery has failed and will not hold a charge. It is uneconomical to replace it.
Nov 22, 2013 | Craftsman 14.4 volt Cordless Drill/Driver...
Have a 15.6v cordless drill - both batteries charge up to ~6v and no more; the red led is on - are both batteries the problem? this is the second charger - drill does not get used very ofter - model of...
See if you can put a volt meter on the metal contacks of the charger to see what voltage it is producing. If you have a friend who has the same drill have him try to charge your batteries and then measure the battery voltage.
Mar 14, 2011 | Craftsman 14.4 volt Cordless Drill/Driver...
My Craftsman cordless screwdriver doesn't charge
you have a short in the battery or charger,,,very dangerous ,,the batt could explode
Jul 27, 2010 | Craftsman 14.4 volt Cordless Drill/Driver...
Craftsman 14.4 volt battery won't charge at all.
you have a bad plug, switch it out with a similar plug (output v). Usually an old hand vac or appliance will work just fine.
Dec 28, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
Batteries not charging
sounds like my charger, not making good contact
wiggle the battery around while pushing down and you can probably get it to make contact
sounds like you just need a new charger
Nov 11, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
Not charging
try wiggling the battery around and see if a light flashes
also look and see if a light flashes when you plug it in
i'm about 98% sure it's the charger
Oct 19, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
Looking for Craftsman Cordless Screwdriver Charging cord
Go to the following link:
http://commercial.searspartsdirect.com/partsdirect/parts/5102970-17/0009/900&pathTaken=partSearch&filterPart=&pop=flush
Sep 12, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
Both cordless drill batteries dead.
Your battery could say its good by just testing voltage,but when a load is put on it , its a different story. My dewalt batt. did the same thing I opened up the batt. case and there was 12 "C" sized batteries inside linked together with little metal strips. I bought 12 rechargeable "C" batts. and carefully drilled where the metal strips are soldered, changed out batt. and re solder. It's been over a year now and still drilling . Also you should do this one batt. at a time so you don't put one in the wrong order .
Mar 17, 2009 | Craftsman Drills
Drills Logo
418 people viewed this question
Top Craftsman Drills Experts
Tim Venetis
Tom Chichester
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
