Question about LG WM-2277HW Front Load Washer
My machine is leaking onto the floor from the bottom Please help me
  • 5 Answers
There is a drain hose connected to the pump that probably has a hole in it due to the bad placement inside the unit. I had the same problem and the hose was rubbing against the drum and wore a hole in it. A tech has to take it apart, unless you download instruction on how to do it yourself.
Posted on Jul 19, 2009
Ice accumulates at bottom of refrigerator, water leaks onto floor if not removed.
sounds like a blocked drain, either by debris or failed drain heater?
Oct 07, 2015 | Refrigerators
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
Water runs out of bottom of drum through machine onto floor
The first thing to check is the bellows, also called the front seal. Look for any tears, if any found, that would be your problem. If not, then the next thing is to take the top off the machine by removing the screws in the back of the upper part of the machine and checking the lines that run from the water valve to the dispenser.
May 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from bottom of machine onto floor during fill and wash cycle
there are 3 bolts are bottom front compartment, may be taken off with a phillip screwdriver, or it may be a torx. when you take it off, cut your washer on and see where it is leaking, your gasket could be broken, your hoses or pump.
Sep 07, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Washing Machine Emptying
Sure sounds like a hole or crack in the tub.  Unplug power, shut off water, and disconnect the hoses.  Tilt the washer onto its front and look underneath.  Use a light to inspect the tub bottom and sides for a hole or crack. If it is small enough you might be able to plug it with silicone sealant.
May 27, 2009 | Washing Machines
Water leaking out of the bottom
Sounds like the main bearing has gone bad and that is causing you to loose water on the floor. There is also a rear seal back there that will need to be replaced
May 22, 2009 | GE WSXH208A Front Load Washer
Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Mar 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Ge washer
Hi.
I would check the rubber seal around the door - down at the bottom, to see if it has perished or got torn.
Does it leak only when running or all the time - that is, when powered off and idle?
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills. If they do not, please add a comment with more details so I can try to help you further. Cheers, D
Jun 17, 2008 | GE Profile Prodigy WPSE4200A
LG WM-2277HW Front Load Washer Logo
110 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
