It is misfeeding after 3 copies and printing multiple images when it does print. Help!
SOURCE: HP 4650N Will not print more than one copy of a job
make sure when printing it has all checked off in the page range box instead of pages
SOURCE: Canon IR 5000 Printing multiple copies of mutliple copies
Dose it do it when you use it as just a copier? I would have to say that the problem lies with in your network some where. Call your IT person.....
SOURCE: My hp 1320 prints only one copy SPAM I AM AT 1*800*532*4187
Windows may have eaten its baby again- that is, the driver for that printer.
Open the Control Panel, then Printers and Faxes, delete any listing for that model of printer, make sure the printer is on and connected, then reboot your system.
This will force Win to 'find' the printer and install an uncorrupted driver for it.
(=Plug and Pray)
SOURCE: unable to store job at printer, printer not configured to collate
Problem
Error “Unable to store Job at Printer”
Reason “Printer not configured to collate”
Solution “Install an EIO hard disk”
Usually when trying to print a multi page document.
Solution
1. Start > Control Panel > Printers
2. Locate the printer > Right Click > Properties.
3. Device Settings > Mopier Mode > Set to Disabled.
4. Apply OK
SOURCE: Brother MFC-7420 just started printing a shadow image
Sounds like a bad drum cartridge. Pull the toner/drum cartridge out of the machine and set it down. Press down on a (blue?) tab to release the toner cartridge, and you can lift the toner cartridge out of the drum cartridge. There is a cleaning blade in there - a soft plastic blade that rides against the drum and scrapes off toner that didn't get transferred to the paper. If it gets stuck off the drum surface, images repeat a few inches (one drum circumference) down the page.
A new DR-350 drum unit should fix it. have the machine's power on when replacing it. While the door is open, touch the CLEAR key. The display will read "REPLACE DRUM?" or something like that. Press 1 for Yes.
