Question about Garden
JD X320 blades stay engaged, always. Narrowed it
JD X320 blades stay engaged, always. Narrowed it down to the clutch, lower magnet won't hold clutch. Machine only has 150 hrs, Any ideas or help, the part alone is $150
  • 155 Answers
Hi you can adjust the gap on these clutches , The recomended gap is 0.10 thou you slide this size feeler guage into the hole on the side of the clutch there is three holes and three adjusting nuts you have to try and get it even .
Hope this is some help
Mark.
Posted on Jul 23, 2009
John Deere x320 PTO switch not getting power. Mower blades will not engage. Replaced PTO clutch and PTO switch. Have checked seat safety switch and RIO switch as well.
Just out of curiosity check your pigtail that plugs into the pot harness. I have ran into a broken wire inside that pigtail before.
Nov 26, 2016 | John Deere Garden
Electric clutch wont engage when when switched on even though I can hear a clicking sound at the clutch.
PTO Clutch will not stay engaged.
There is a very fine one page discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
  • Resistance 3.7 ohms
  • Current Draw 3.25 amps.
It does not give the air gap. It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
  • Cap Screw torque 55 lb-ft (75 N.m).
Fixing Electric Clutches
Apr 11, 2015 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Only after i got stuck in mud did blades on snapper lt 200 42 rider so working belts are tight must be sensor insert seat went out or went bad
Blades would not turn after I got stuck in mud. Electric clutch?
  • Turn the engine off and remove the key.
  • Check for physical damage; anything look bent?
  • Spin the pulley on the bottom of the clutch. Does it spin freely?
  • There could be mud or grit stuck in the clutch.
  • There is a drive key between the clutch and the shaft. Has this key been sheared? It's possible the clutch was burnt out during the mud incidence.
PTO Clutch will not engage or stay engaged.
There is a very fine discussion on evaluating electric clutches at this site:
  • It does not give the air gap.
Apr 10, 2015 | Snapper Garden
Blades won't engage after got stuck in mud electronic pull on blade engagement
Blades would not turn after I got stuck in mud. Electric clutch.
  • Is the deck belt intact?
  • When you pull the PTO switch does the clutch make a "click"? It's possible the clutch was burnt out during the mud incidence.
Apr 10, 2015 | Garden
Pull switch on blades but they won't engage worked fine until i got stuck in some mud now won't engage
How to fix JD x320 grass height level and blade engagement
Check if lever come unhooked or a stick or something blocking it.
Oct 21, 2014 | Garden
Tractor quits when engaging the blades
unhook clutch and see if blades stop turnig and then try engage clutch with the switch if motor stays running bad clutch
Jun 01, 2013 | Mtd Garden
JD STX38 mower stalls when deck is lowered
If the belt bounces then it has stretched or the belt tightener is not working. properly. Also check the shear pin in the drive pulley. If it has sheared the blades will try to turn but slip when any pressure is put on.
Jan 07, 2018 | Garden
John Deere 318 blades won't engage once it gets hot.
Check the clutch gap in the front of the machine (the one that engages the belt) by tightening or loosening three lock nuts around clutch. Tightening decreases gap/ loosening increases gap. Note: do not tighten too far as it will result in clutch drag or lockup! Stop when its just starting to touch then back off slightly. Also without a proper charge on the battery the magnetic power for the clutch is altered and not strong enough to engage clutch when hot. Find out why battery light is on.
May 01, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
172 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
