Hi, you didn't say if the mic actually passes sound? The C-1 is a condenser Mic & needs phantom power - switch on the rear of your mixer. If that's no help, what happens if you disconnect the mic, then turn the levels back up? Still hissing or gone? If it's gone then it's the Mic - must use a 3 wire cable, preferably XLR so it gets the phantom power. If the hiss is still there without the Mic then sounds like the mixer is faulty - try some of the other channels..... How loau is the hiss - just in the background or as load as a vocal "one, two" test? A few things to check anyway...... Good Luck!
Assuming that you've checked the fuse, and the lights come on...
1) Can you hear any "hiss" from the speakers at all? 2) What have you tried to input into the device? (guitars, keyboards, mics, etc.) 3) Have you reset all buttons to "basic" mode?
You are running your balanced cable into a windows 7 PC? What interface are you using... not the line input on the PC I hope as it is NOT balanced... it is Stereo input with UNBALANCED input. If you tie the mixer using a balanced to 1/8 inch balanced connector you will get plenty of hiss since you are driving the stereo channels oppositely. For high quality, get a good audio interface that runs on the USB of the PC. If you can tolerate a bit of noise but wire it correctly, then you will need to use two UNBALANCED lines out of the mixer for L and R and merge them to a stereo 1/8 inch plug for the PC.
Most of these have a SETTING in the menus that selects the source from different mics and/or line inputs. If the setting is to the line input instead of mic, and no audio is connected to the line input it will act like you described.
hissing sound when recording is due to old microphones or frequency interuptions if you have a wireless mic i suggest you to find a new mic, or if you have singstar use their mics
First turn the unit off then rotate the input level volume control. If it feels loose pull up lightly on it as you do this. Also rotate all your controls that you don't normally use a lot. Chances are the pots are dirty. If that doesn't help you might want to check all the connectors inside the unit if you feel confident enough to go poking around. Other wise I suggest that you find a shop that will fix the problem. If you do go poking around make sure the units unplugged and that you have grounded yourself against static discharges.
I presume you are going in through the mic socket on the audigy?
If so the most likely cause is a mismatch between the mic and the mic amplifier on the card, they are designed for cheapo condenser mikes that have a fairly high output.
Also make sure you disable any inputs that ar'nt in use to minimize noise.
If you have the Mike plugged into the line in you have it in the wrong socket.
The best way to get a good result is use an external mic amp or mixer and go in through the line in. Again make sure you disable any inputs your not using (in the computer mixer) and turn down any sliders on the external mixer that ar'nt in use to minimize noise.
If you'r still having problems get back to me with a more detailed description of your setup, whats plugged into where etc...
1) if you are using the PC sound card to record this is where your hiss is coming from. you need to get a recording card that has low noise or some other recording USB input device to get CD quality recordings
OR
2) if you have to use your PC sound card check your PC volume level for line in, don't let it get high or it will distort. you will have to experiment with the MD4 levels and PC sound card level to find a good middle ground with low hiss and no distortion
and a singer that sings away from the mic to reduce distortion.
