Question about Singer 3820 Mechanical Sewing Machine
Needle drops too far to the left and hit the metal plate
bargainbox
  • 1388 Answers
SOURCE: Needle hitting bobbin plate
Is the needle inserted correctly with the flat side at the rear and fully up into the holder ?
If yes, take off the needleplate, remove bobbin case and slowly rotate the handwheel towards you watching the relationship between needle, and the "hook" of the moving "race".
Set on wide zig zag........when the needle is fractionally past it's lowest point, and starting to rise, the hook should be level with the left side of the needle when on the right hand stitch of the zig...the eye of the needle will be below the hook, and ready for thread to be picked up for the stitch to form.
Any other result will mean your timing needs adjusting.
Posted on Feb 10, 2008
  • 5 Answers
SOURCE: Needle hits the plate that is over the bobbin.
If possible hoop the item. I have found that any item that has any thickness causes the presser foot to be pushed forward and the needle hits it and breaks. If you can press the item to lessen the thickness this may help. I spoke to Singer (I am a Singer dealer) and they did not have any help for this other than to recommend that the owner cut out the back of the foot. I don't think that would be a solution as it would be difficult to cut out the back of the foot and still have smooth edges, also it would cause the foot to be weak and possible break or bend. Good Luck
Posted on Feb 26, 2009
  • 23 Answers
SOURCE: Needle hitting metal casing .. Singer Futura CE 200
It happend to me aswell , not getting the source of the problem!
Then I noticed that the bobbin casing was out of the original position, take the whole casing out and make sure that when you put it back that the small metal tension loop at the front side on the right is correct, this image you can see in your handbook, (placement of the bobbin casing)
Posted on Feb 27, 2009
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
  • 1514 Answers
SOURCE: My needle was hitting the
The most common reason for this is that the bobbin case is inserted the wrong way. There's a slot on the bobbin case. When it's inserted into the machine this should face up. The needle comes down through this slot and picks up the thread from the bobbin. If it's put in the wrong way the needle hits against the case and cannot get through to the thread on the bobbin.
The other possibility is that the new needle doesn't fit properly. It may not be pushed fully up into the machine. Sometimes this can happen if the needle is too thick for the machine or if the screw wasn't loosened enough to allow the needle up fully.
Posted on Sep 12, 2010
My needle is hitting the metal plate on a singer cg590 sewing machine. Is there a way to adjust it back into its correct position?
Your needle plate may have been place incorrectly, and it's easy to do. Even the slightest variation can cause the needle to hit it. Try taking the metal plate off and then reseating it -- testing the needle position before you tighten the screws.
Dec 18, 2016 | Singer Sewing Machines
Pixie plus sewing machine needle does not go down into the bobbin but hits the metal plate on top of the bobbin. The needle cannot go through the sewing slot.
Sounds like your needle is set to off-center. Check your manual. You may have a straight-stitch plate in your machine but you have it set to stitch off center or it is set to zig-zag stitch and the needle is unable to clear the stitch plate.
Aug 13, 2015 | Singer Pixie Plus Sewing Machine
My needle keeps hitting the metal plate, and its a brand new needle. It seems like the alignment of my brand new machine is off. Basically, the needle keeps hitting the metal plate where the bobbin is, and...
Check whether the needle is installed correctly - maybe it's turned around from machines you are used to. Also verify that the needle plate is installed correctly, not upside down (may be possible on some machines). If the needle and plate are installed correctly, then something is out of line, and you're owed a free adjustment or repair from the manufacturer.
Feb 10, 2015 | Sewing Machines
I have a Kenmore model 1690. The needle when it goes down does not hit the hole in the foot plate. It comes down too far to the left of the opening, making it impossible to use the machine. I have...
This machine, when you have it on straight stitch, will sew with the needle to the left. If it's hitting the pressure foot, you may have the wrong pressure foot on the machine. If it's hitting the needle plate when you have the pressure foot removed, it's possible you have set for zig zag and you have a straight stitch needle plate on the machine. I believe this machine came with 2 needle plates. One for straight stitch, and another for zig zag.
May 03, 2011 | Kenmore Sewing Machines
The needle is entering the machine far to the left. The needle is in correctly and the bobbin plate has not shifted. It appears that the device holding the needle from above has shifted (it shifts easily...
Is your needle position selector stuck? Try moving the dial back and forth a few times. Have your oiled your machine lately? You manual is available on Singerco.com and is free to download. Good luck
Oct 05, 2010 | Singer Inspiration 4210 Mechanical Sewing...
THe needle hits the base plate about 1mm on the far side of the hole.
You may have the stitch setting on the left/right(depends which side it hits) setting, or the needle is un-noticeably bent. Depending on where the needle hits, if you are in zig-zag mode and it is hitting the base plate(wide slotted base plate req'd) the machine may need re-setting of the needle stops(if fitted). This is uncommon so its more likely to be a bent needle.
Mar 20, 2010 | Sewing Machines
When i use my janome overlocker the needle is hitting the lower looper, and therefore breaking. This is happening with both needles. I have taken the covers off and the needles are hitting the metal. Is it...
Here are a few things to try.
* When you insert anew needle, make sure it’s positioned correctly. Usually with the flat side
away from the bobbin, but consult your manual. Make sure that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot
Make sure it’s attached securely.
* Change your pressure foot
Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins
A needle that hits a pin can break. Always remove the pins from your fabric before they reach
your needle.
* Don’t pull your fabric as you sew
You could be bending your needle back, causing it to hit your needle plate instead of going into
the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate
Make sure it's securely in position.
* Change your needle plate
If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for
sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle
Sewing machines with zigzag capability allow you to adjust the position of your needle – right,
left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or
pressure foot.
I hope one of these solutions help you.
Sep 14, 2009 | Sewing Machines
The needle hits the throat plate
if a new needle still wont align with the needle plate, your needle bar is out of whack
Mar 18, 2009 | Brother CS6000i Computerized Sewing...
Singer 3820 Mechanical Sewing Machine Logo
118 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
