Question about Dell Inspiron 6000 Notebook
Clicking on anything and computer goes overboard
I'll either be working in Photoshop or opening anything on the internet and I click on something and my computer is hyperactive - opening extra links and in photoshop will zoom in several times when I only want it to once
.psd file in photoshop 18.0
Ultimate solution which might more effective than all listed is photoshop repair corrupted file
It is helpful tip
This one artilce from Adobe, is also can assist you
· Open "My Computer." In Windows XP, the icon is on the desktop. In Windows Vista or Windows 7, you must access this via the "Computer" option in the Start menu.
· Double-click the "C" drive, followed by the "Windows" folder inside. Locate the temporary Photoshop folder, which will look similar to this: "Photoshop Temp6382948398." Double-click the folder when you find it.
· Locate the file inside the temporary folder that matches the name of the corrupted file. Double-click it to open it in Photoshop.
· Click "Save As" in the "File" portion of the main menu bar. Save it in a different location and under a different name.
Photoshop Repair Toolbox Solve Adobe Photoshop problems and issues by keeping it up to date https://helpx.adobe.com/photoshop/kb/file-recovery-photoshop.html
Aug 17, 2017 | Computers & Internet
How to connect it to a wireless network do i need a wifi adapter for it or what??
Hello danieljkeena,
"There are (4) four different ways to connect to the Internet.
in the (right "start menu" pane), select the Control Panel 'shortcut'.
Once the next window open; scroll to find,
click on it to open. Next, select to open the "Internet Options."
paul7of9_22.jpg To setup the Internet Connection:
Click on the "Connections" block, click the ("Setup") button,
paul7of9_23.jpg and follow all the instruction carefully.
2) From the "Start Menu" in the (right) menu!
If you have the "Connect To: Icon?
Click on the icon to open; "this will start the setup and connection process."
3) Click on the "Start" button, select to open "All Programs."
Next,scroll to find: the Product's name; example (Toshiba).
Cick to open. "If there is a ConfigFree icon present"
paul7of9_24.jpg Option is available?"
select to open, and click on the Connectivity Doctor.
paul7of9_25.jpg Follow the instructions!
4) From the "Start Menu," click on the "All Programs.
Scoll to find "Accessories," and open.
If you have the [Windows Mobility Center]?
,paul7of9_26.jpg Open the program.
There will be a {Wireless Network} "Turn- on / Turn-off Switch!
paul7of9_27.jpg Important "Always! Click Apply, Ok,
Restart the computer after making changes to the computer."
"If you nedd help with anything else?
Write a 'comment'; I'll be here to assist you!"
"Best Regards"
Jul 30, 2011 | HP Pavilion ze4101 (F4902H) PC Notebook
How do i install adobe in my system from net
Directly installing Adobe Photoshop 7.0 from internet is not feasible.
Download setup or use Adobe Photshop 7.0 CD to start installation.
Close anyprograms or applications that may be currently running on the computer. Saveany open documents that may also be open to avoid losing work during theinstallation process
Insert theAdobe PhotoShop 7.0 software installation disc into your CD-ROM drive. Allowthe computer to run and detect the installation disc. Upon detection, the AdobePhotoShop 7.0 Setup Welcome Screen will load. (Skip this step if the setup is located in the PC, click the setup icon to Start the setup)
Click"Next" on the Warning screen that will open after the Setup WelcomeScreen redirects. Select theradio button that applies to your personal status and ownership of the program,whether it be Individual or business.
Type yourtitle or salutation, first and last name, and company name (if any), in theUser Information window's designated data forms.
Enter theserial number 24 digit serial code in the six blank data form boxes at thebottom of the User Information window. Click "Next" to advance to theFile Association settings. Click the"All to PS" and "All to IR", which indicates that PhotoShop7.0. supports all file types, and click "Next" to begin installingand copying the software's files, functions, and components to your computer'shard drive.
Click the"OK" button in the pop-up window that will appear to conclude theinstallation process.
Jan 21, 2011 | Adobe Photoshop 7.0 (321115627)
All the images on my computer have converted from Photoshop programme to Quicktime. I can no longer use the applications in Photoshop. I have gone into tools and said open with photoshop but that does...
To resolve this issue right click on an image on your computer (preferably a photo), select "open with" from the sub menu. If Photoshop is in the list don't choose that, select choose default program instead.
A new window will pop up, if Photoshop is in the list of recommended programs highlight it and make sure the "always use the selected program to open this kind of file" box is checked (with a tick in it) and click OK. Photoshop should automatically open the image for you then and for the rest of your images.
If Photoshop is not in the list click on browse and navigate to local disk C\Program Files for the Photshop program, Click OK and you should be good to go.
Regards.
Sep 15, 2009 | Computers & Internet
Dektop icons doesnt show up! cant open control panel!
Sounds like something viral to me. If you are able to connect to the Internet I would suggest downloading and running a tool called combofix. Information on how to use it and links to download are here. I've used this on several XP systems to get rid of some nasty stuff, but never had to try it on Vista yet. If the trouble is not from a virus but just because something else has thoroughly screwed up the registry, you might have to restore your system.
Apr 30, 2009 | Microsoft Windows Vista Home Basic Edition...
Desktop icons doesnt show up. cant open 'my documents' 'control panel'
if you put your vista disc in and boot from that you should be able to go to a point when it was working or do a repair install.
If you need to do a repair install make sure you back all of your data up before you do it.
You should be able to use firefox or internet explorer to navigate the C drive to navigate and find all the documents you want to save etc and you should be able to copy it to a memory stick or external hard drive.
Apr 30, 2009 | Computers & Internet
I can't open my adobe photoshop 7
This type of problem can clear by "Right Click" on Photoshop 7 Icon and click on "Run" option then "uncheck" the Protect my computer... then click ok..
or
create a new account on Windows and try in new user 100% working
Mar 17, 2009 | Adobe Photoshop 7.0 for PC
I log my details in and then it freezes with a blank screen - nothing !
Hi
Have you tried deleting stored cookies and temp internet files
If you are using Internet Explorer
Open Internet Explorer and click on the "Tools" menu.
In the "Tools" menu, click on "Internet Options".
The Internet Options pop-up window appears.
Under the General Tab select the "Delete Cookies" button.
Delete cookies by clicking "OK".
Select the "Delete Files" button to clear the Internet cache. Make sure to check the box to "Delete all offline content".
Delete temporary Internet file history data by selecting "Clear History".
Restart your computer and try to log in again, this should fix your problem
Sep 25, 2008 | Facebook Social Network
Installing photoshop software
Open My Computer, Right click on the CD drive icon and click Explore.
When the folder opens look for a icon usually called Setup, or Install, or something similar. May be PSP Setup.
Click it or Double click it and follow instructions.
Mar 31, 2008 | Adobe Photoshop 7.0 for PC
How can i mix two photos in adobe photoshop 7.0
open both the pictures on the working area,
select the region from any one of the picture that u need to clone on to the other using clone tool.
now go to the other picture press the right click button on the mouse and just scribble....the selected area from the other picture ll just be redrawn here
Jan 04, 2008 | Computers & Internet
Dell Inspiron 6000 Notebook Logo
29 people viewed this question
Alun Cox
