Question about GoVideo Go Video DVD/VCR Combo
Picture is not on the screen. I cannot seem to
Picture is not on the screen. I cannot seem to connect it properly with cable box
Alot of times you have to back up the TV to something like LINE 1 or LINE 2. It will not show up with the TV on channel 3. When I attached my VCR, I hit input and line 1 and 2 came up and then the DVD player would play just fine. Try that.
Posted on Jul 18, 2009
Hitachi 35CX30B 35" TV cable connection problem.
Check the cable connector, poor signal cause the blue screen
Or check the tuner if lose solder
Jan 09, 2014 | Hitachi 35CX30B 35" TV
We bought a used Philips 42" flatscreen digital TV with no remove and hooked it up to our cable box. It works beautifully but we have not able to reset the screen size using the side buttons and menu...
Yes there is a trick. Usually the cable box and its remote determines the picture's screen size. First off, this television is able to display hd on an hd cable box. Make sure that this cable box is connected with this television the hd way only. It should only be connected to your television with either a component (green,blue,red, white, red) cable OR and hdmi cable. The coax cable should not be used to connect the cable box to the television if you have an hd cable box. Next make sure the television is on the proper input/source to display the cable box in hd.
Now if all of this has already been done, look for the hd zoom # button on your cable remote. It is usually towards the bottom. When you press it you change the screen size. You can buy a philips remote-the original one for your television at http://www.replacementremotes.com if you need the wide/stretch/zoom/viewmode button to further adjust your picture size.
Jul 16, 2011 | Televison & Video
I have a symphonic flat screen tv. i am trying to connect it to a comcast cable box. i keep getting a message... protected program by TV-G. what does that mean and how do i get it off the screen.
Check the set by any other cable connection or use any AV input if you receive proper picture than your TV set is o.k,problem is with cable box,contact cable service provider to solve the problem.Also check by simply removing cable box the message will disappear.
Jan 31, 2011 | Symphonic Televison & Video
Screen suddenly went to complete snow no video or audio
Well the LG tv is not getting the cable signal.Unplug the cable box about an hour.Replug the box let the software to upgrade the cable box.The LG tv should get the signal back as normal.Not,than the LG tv Tuner board have problems it dead.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Apr 21, 2010 | LG 32LG30 32 in. LCD HDTV
Sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Feb 05, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
No picture, blue screen
Use the TV input selector to select the right channel, that should fix it.
Jan 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
Sony Bravia - picture don't fit the screen
I have a Scientific Atlanta cable box w/ Time Warner. I followed the instructions below for the cable box. Somehow it reset my picture and I can now read the ticker at the bottom of the screen and the different picture sizes seem to work properly. Good Luck.
http://newteevee.com/2007/12/15/six-steps-to-get-more-hd-from-your-scientific-atlanta-set-top-box/
Aug 03, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Cannot fill screen with normal picture size setting
assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in depth..lol...
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
voila....
now check your tv settings to accommodate
Nov 17, 2007 | Sony BRAVIA KDL-40V3000 Television
Picture seems to fall off the screen.
Julie,Did you by Chance have a Projection tv down stairs,If so Contact you Cable Company for Proper Settings......
Jun 22, 2007 | Sanyo DS25390 TV
GoVideo Go Video DVD/VCR Combo Logo
168 people viewed this question
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
