Question about Kato Toys
I have the kato double track layout and the blue power box
I have the kato double track layout and the kato blue power bOX. I have no clue where to put the cord after it plugs into the blue box. I can not find where to plug into the track. There are about 3 blue and white cords without a proper explanation. The cords have wires and the end and another one with the wire inside a small covering. This is insane
  • jfmusialek Jul 18, 2009
    does it have a metal plating.
    yes very
  • 19,396 Answers
The connector is wired at the bottom of a special feeder track, if you have no feeder track you need to buy one.
See also feeder track picture on the brochure here on the left.
If tracks are not Kato, depending on the tracks you are using , you may need an accessory connector. See Wiring with Kato Connectors.
Do not forget to leave feedback .
Regards.
Posted on Jul 18, 2009
Do you know what the pin layout for the charger (Dell Latitude CPx PA-9) is?
I do not agree with butchering the adapter but here may be a clue. There are three wires, The blue tells the adapter it is plugged in to the laptop. The outer sheath is 0v and inner sheath is +ve.
Sep 29, 2016 | Computers & Internet
Fuse box layout for a 2007 isuzu double cab
open glove box see opr. guide, its there.
look in actual box, see the labels? bingo;.
if not enough you need a real FSM. to get a real wiring schematic
there is no other way.
FSM = Factory Service manual. sold by ISUZU, dealers world wide.
Jul 09, 2014 | Isuzu Pickup Cars & Trucks
What is the fuse box layout for 1986 Lincoln Town Car?
Here is a recap by fuse/CB:
1. 15 amp -Light Blue
2. 8.25 amp -CB
3. Not Usable
4. 15 amp -Light Blue
5. 15 amp -Light Blue
6. 20 amp -Yellow
7. 10 amp -Red
8. 15 amp -Light Blue
9. 30 amp -Light Green
10. Not Used
11. 20 amp -Yellow
12. 20 amp -CB
13. 5 amp -Tan
14. 20 amp -CB
15. 10 amp -Red
16. 20 amp -Yellow
17. 15 amp -Light Blue
18. 10 amp -Red
Do you have a problem with a specific device? Let me know and I may be able to tell you what Fuse/CB.
Jul 23, 2010 | 1986 Lincoln Town Car
I need to install or downloads Arabic language into my computer languages so I can type using Arabic keyboard thank you very much sam
Setting Up Arabic in Windows XP
Adding the Language to Windows
The following instructions will help you to set up your keyboard layout for Arabic that matches the DataCal Keyboard Labels.
Step 1. Install Supplemental Language Support
The Arabic language requires that you install Supplemental Language Support before you can set it up in Windows.
  1. Select the Start button in the lower left corner of the Desktop.
  2. Select the Control Panel (or, if you are using the Windows Classic Setting, select Settings > Control Panel).
  3. In the Control Panel, double-click the Regional and Language Options item.
  4. In the Regional and Languages dialog box, click on the Languages tab. In the Supplemental language support section, click on the Install files for complex script and right-to-left languages (including Thai) option (see Figure below).
  5. Click on the Apply button in the lower right corner of the dialog box and then click on the OK button. You may be prompted to insert your Windows install CD into the CD drive.
Step 2. Add Language to Windows
  1. In the Control Panel, double-click the Regional and Language Options item.
  2. In the Regional and Languages dialog box, click on the Languages tab.
1. Click on the Details button in the Text services and input languages section of the Language tab to open the Text Services and Input Languages dialog box.
2. To add a language, click the Add button in the Installed services section to open the Add Input Language dialog box.
3. Click on the arrow to the right of the selector in the Input language selector and scroll to Arabic.
4. The Keyboard Layout/IME should default to the Arabic keyboard layout. If it does not, click on the arrow to the right of the selector in the Keyboard layout/IME selector and scroll to the Arabic keyboard layout. Note that there often are different keyboard layouts for a language. You should select the language and keyboard layout that matches the DataCal Keytop Label.
5. After you select the language and keyboard layout, click on the OK button to close the Add input language dialog box.
6. When you return to the Text services and input languages dialog box, you will see the new input language and keyboard layout included in the Installed Services box.
7. Click on the Apply button to apply the changes to the new layout. Note that each language features a small blue box in the Installed services section with 2 letters that indicates the language. English is designated as EN.
  1. If you do not wish to add any additional languages or layouts, you can click on OK to close the Text services and input languages dialog box. When you return to the Windows Desktop, you can see the language bar in the lower right corner of the Desktop.
  2. To change the language and keyboard layout, click on the two-letter language selector box with the left mouse button to open the language selector menu.
  3. Click on the language that you wish to use in the language selector pop up menu.
The language you select will remain in effect in active Windows application until you select a different language. For example, if you select the Arabic language and keyboard layout in Microsoft Excel and English in Microsoft Word, each application will use that keyboard layout until you exit the application or you select a different language.
Default Keyboard Layout
If you wish to make a particular keyboard layout the default Windows layout (i.e., to be used in all Windows applications), open the Text services and input languages dialog box.
Select the desired keyboard layout to be the default in the Default input language section of the dialog box.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 27, 2010 | Microsoft Windows XP Professional for PC
Kato locomotive doesnt run. Goes for a short time with spray of contact cleaner then stops
That means that your track is dirty. Your locomotive is picking up dirt from the track, which builds up. on the wheels. Use a track cleaner NOT alcohol... the alcohol does leave a residue on the track after it dries.
Jan 10, 2010 | Kato N Scale, Amtrak P42 Superliner Train...
Thomas the train blue track layout
Try looking for your set here and downloading the manual
http://www.tomy.co.uk/webcare/product-instructions/track-master-tmrr-instructions/
Dec 21, 2009 | Tomy Thomas The Tank and Friends Track
Fuse box layout for 1996 Fiat Cinquecento?
usually on the under side of the fuse box cover there is sticker with the layout of the different fuses. Look in the owners manual that's in the glove box, that should show the layout.
Nov 10, 2009 | 2006 Fiat 124
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
How to print duplex
I am not sure of your printer,
Bu,t go to your printer's properties, preferences or advanced tab,
then page layout, in here you have the box named.
" double sided printing" or Duplexing.
Tick the box,
you should be good..
Hope this helps
Regards
Richard.
Apr 21, 2009 | Office Equipment & Supplies
Toys Logo
46 people viewed this question
Top Kato Toys Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Kato Toy Expert? Answer questions, earn points and help others
