Question about Audiovox AVT988 9" TV
Audiovox AVT988 9" TV Problem
We just purchased an older van, and the tv that is in it, the sound will work, but no picture. We brought it in the house, and has the same problem. I am thinking about taking it to tv repairman to see what he can do, since the tv has a special plug I guess, so the passengers in the back can use headphones. What do you think? Thanks!
  • UCBoo Feb 09, 2008
    We just purchased a dodge caravan and are having the exact same problem with the tv no picture just sound. I was wondering did you ever get yours fixed or find a replacement tv. Please let me know. I have a 2 year old that really misses his tv.
    David and Angie Casey
  • YNOTGOD Dec 05, 2008
    my problem is backwords i get a picture but no sound !
  • 749 Answers
Guess there is a problem with the video Circuitry of your TV. it could be as simple as cold solder or could be worse as IC troubles. if you have no experience with electronic troubleshooting/servicing then its better if you send for repair. since there is still sound from your tv, it won't have a major problem.
Posted on Nov 19, 2007
Picture went out on 2-year-old Samsung TV model UN50EH5000F. I have sound and full backlight but no video.
You have replaced everything that could have gone wrong - except for the video Screen itself. Check the connections (ribbon) to the screen for oxidation - use eraser to clean.
Jun 20, 2017 | Samsung Televison & Video
Shrunken picture
can you take a picture to your tv to see exactly what happen to your vertical problem!? then you can post here thanks!
Nov 02, 2007 | Proscan PS56670 56" Rear Projection...
Both the picture and sound work when the TV is turned on, yet the picture is distorted like a double picture and has a yellow hue to it.
Sounds like you have a convergence problem. If you go into the setup menu of your TV, there should be some settings to adjust the red, green and blue hues and re-position them so each color matches up. If this does not work or if you don't have a menu, your TV *might* have a circuit board with several plastic screws on it. These adjust the picture and it's a very tedious task to re-align each hue correctly.
My projection TV is an older model from 1995, which is probably why it has this circuit board in place of a convergence menu built into the TV.
If adjusting the convergence still doesn't work, you might need to purchase a new convergence chip.
May 20, 2011 | Sony KP-51WS520 51" Rear Projection...
My son purchased a rear projection Zenith Z52Z95D for next to nothing. It I would guess is an older television and I would like some input on whether or not it's worth it to repair. The picture is dark and...
Jan 05, 2009 | Zenith Z52Z95D TV
Older 36 inch rca crt tv broken
Your high Voltage anode button that connects into Picture tube may have came lose Rember Picture Tube if not broken Holds 36,000 volts if not discharged, Have you Look under chassis to see if board it cracked? Sounds like your FBT?
Dec 23, 2008 | RCA D52W23 52" HDTV CRT TV
Older model jvc tv purchased late 90's
I am not receiving a satellite signal on my old model JVC model AV 32F704
Dec 21, 2007 | Televison & Video
Went from great picture to black after a couple of flickers. Sound Great.
that would be the flyback could also check in this area
Nov 06, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Phillips tv 32pw9544
it is 100% sure that your tube is ok.
there are few problems in different section like
  • sound section for no sound
  • video & crt base  due to low light in picture.
  • red video output circuit.
  • though problems are very easy & can be fixed at your house.but you need skilled technician.
Oct 16, 2007 | Televison & Video
RCA HD52W59, Serial: G075CN0AO, Chassis # 1TC222A
ask your service depot about the service flash on the covergence connector,causes intermittant faults and deflection problems /
Aug 22, 2007 | RCA HD52W59 HDTV Projection Television
No picture but has sound
Hi If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service. Good Luck!
Aug 14, 2006 | Zenith DVB312 DVD Player
Audiovox AVT988 9" TV Logo
188 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
