Question about Ventamatic Ltd. VENBF24TF2N1YEL Maxx AirTM 24" 2-in-1 Tilt Fan
I need a replacement for my electric motor powered attic Ventamatic vent fan cover. The old one has developed leaks. The diameter of the cover is approimatley 24 to 25 inches. Where can I find one? Thanks, Joe Robertson jbrvector@aol.com
  • Anonymous Mar 14, 2014
    hello;
    I need the wiring lead color to terminal number in order to wire my century/gould 1 hp 1725 dual voltage reversable capacitor start electric motor. p/n 150110-01. I have no diagram on the terminal cover. thanks Charles
  • 142 Answers
If you are talking about a power roof vent, you would be better off installing a whole new unit.
it will be cheaper in the long run
Posted on Jul 18, 2009
I need a belt for a very old attic fan. The belt number is 4689, the Model # is BV24, Serial # N and Catalog #BV2458
I have an old robbins and myer attic fan. The motor is bad and there is no sticker let on the moter saying what hourse power or voltage the fan is. The model number is BV24. I couldnt find anything on the web about this model. Does anyone have a clue what kind of motor i need
Aug 11, 2013 | Broan-NuTone N-GF900N Gable Fan Attic Fan
I have a safe but cannot find what model it is
Not all locksmiths specialize in safes, but if you can find one, it will take this person since he does this stuff all day and is probably familiar with your unit. You'll need to shop around the locksmith community for a referral. . Sorry I can't be of more help.
Nov 25, 2009 | Ventamatic Gable Mount Power Attic...
I have 120v going to fan ,thermostat has been put on 80 degrees and it still won't work .Do the heat sensors go bad ?
The heat sensor or thermal switch can go bad, so can the motor.
Try a few things;
shut off power going to fan. try cleaning out the thermostat housing using some compressed air on low pressure, or use a vacuum cleaner on blow, or a hair dryer on no heat. you can also spray the inside with contact/motor cleaner(home depot electric dept.) and then blow the thermostat out of any dust or particles that may have lodged inside.
To see if the thermostat works at all, turn power to fan on. Take a hair dryer on heat and place near thermostat - to see if fan comes on.
To rule out a bad motor, the thermostat can be bypassed by hooking up the feed wires to the fan itself, if you're handy with wiring.
Ventamatic web site does list replacement parts for fans... Good luck!
Jul 21, 2009 | Ventamatic Gable Mount Power Attic...
Replace old attic fan motor, or replace the entire fan assembly.
I am assuming you replaced your fan by now. However in the future call Gibraltar Industries, they are the ones who manufacture all fans and motors. My attic motor fan also died and I first called Ventamatic and they wanted $65 for a new motor. I then called Gibraltar and they shipped one our for free. 800-527-1924.
Jun 26, 2009 | Ventamatic Gable Mount Power Attic...
Attic fan stops running after one hour
I need to verify you have adaquate air flow, to cool the motor. If you have a window open, and the crawl hole open is there enough air flow into the the attic? It there is enough air flow and it still stops after about an hour, does this unit have a humidistate and a temperature switch on the housing or extension.
If all the switches are working correctly then I could be the motor overloading/heating shutting down and then reseting.
InMrFixIt
Oct 12, 2008 | Ventamatic Direct Drive Whole House Fan...
Broken mount attic exhaust fan
buy new blade or keep soaking shaft.collar with rust penetrant,
Jul 25, 2008 | Ventamatic Gable Mount Power Attic...
Attic roof vent fan- brand unknown. need motor and blade
Any Blade will be ok if it will fit shaft and they all should be cosistant and of course the higher the amp the better quality.I like the Pro 3 model at Home depot but I believe the Pro 1 gable is the 12 inch blade,pro 3 is 17 inch houseing and maybe 12 inch also.
Please rate jj505 Guru
Jul 11, 2008 | Kitchen Ranges
Need replacement motor for Ventamatic Attic Fan
common motor. get from butler ventamatic or Johnstone Supply if you have an account. Hint, buy a whole new fan for $60; cheaper then buying piece by piece, then you get a new blade,motor and tstat for a little more then motor alone costs.
Apr 26, 2008 | Ventamatic Gable Mount Power Attic...
Ventamatic Ltd. VENBF24TF2N1YEL Maxx AirTM 24" 2-in-1 Tilt Fan Logo
87 people viewed this question
Top Ventamatic Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Ventamatic Measuring Tool and Sensor Expert? Answer questions, earn points and help others
