Usually broken dial tone means the line has call-forward set. You get broken tone for 3 or 4 seconds, then goes back to normal. Are you receiving incoming calls normally? It's common to set or cancel 'cause the code might kinda match a number you use. And it may be forwarded to nowhere, example, you dial 729-1111, but press 72#-1111. You might be forwarded to 1111, the code being 72#. The 1111 goes nowhere, someone calls you, calls gets forwarded, then they get a message"that number does not exist". If that's the code for your area, then 73# might be the cancel code. Check the front of the original phone book, or Google codes for your service provider.
Yes, i able to break the lock code just follow these steps
another method insert AA batteries press program button press dia lock press 1111 then press program again thats it Leave feed back, if it works.....enjoy [email protected]
have you replace the spiral cord of the handset? if you do may the handset is defective, try replacing the handset, if you have extra unit try to borrow and connect it to your phone just to see if its good or not.
This worked on my KX-TG3611BX and might work on yours: Turn the dial lock off using the following method: 1 {MENU} --> {#} -> {2} -> {5} -> {1} 2 Press {*} -> {7} -> {0} -> {0} -> {0} 3 {Save} -> {Yes} -> {OFF}
