Question about Whirlpool WFW9500TC Front Load Stacked Washer / Dryer
Load capacity I just bought the Whirlpool Duet Steam 4.0, and I'm having trouble gaging how much laundry I can actually put in the washer for a large load. This is my first front loader and I know you're supposed to be able to wash a large amount, but could someone give me idea of how to gage, I don't want to overload. Thanks!
    Problem Solver:
  • 16 Answers
2/3 of the drum to the top loosly packed.... no more than that ... the clothes have to drop from the top and down to wash properly, and if overloaded you can rip the front boot off.....300 dollar repair....use he detergents and only use 1/5 of the cap as you have very little water in the washer.....Try to do atleast 2 hot loads a week to avoid mold and mildew smells and buildup....I have been fixing washers for 14 years please follow my advice
Posted on Jul 22, 2009
Can you stack this washer and dryer?
You can stack, will you be able to reach. Racks can be made to stack any normal washer and dryer.
Mar 14, 2016 | Whirlpool WFW9750WW Duet Steam Front Load...
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
My dryer is making my clothes soaking wet every time I put clothes in. How do I turn the warer off on the steam mode (I guess)
Same problem here....I have had my brand new Whirlpool Duet Steam front load washer for a whole 4 days... It has worked perfectly until now. I checked on the clothes because it seemed like they just kept going and going... they were soaking wet!! When I took the clothes out the dryer had a huge puddle of water in it..Can anyone offer any help?
Sep 30, 2010 | Whirlpool Duet Steam WFW9700V Front Load...
Washer stops during begginning of cycle with F 35 reading .
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 13, 2009 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Whirlpool WFW9600T Washer - How do I run diagnostic mode?
Actually, on my particular whirlpool steam duet model, I had to press the deep clean button four times to make it go into diagnostic mode.
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Vibrating Whirlpool ghw9100lw2
At Lowes you can purchase foam rubber pads 4"X5" pack of two for $3.50. If walking forward and after cecking level and washer pads are tight, place half of one pad under each of the two front feet. Place the sticky side against washer feet. Solved my problem.
Feb 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drain
kathy..theres three screws at the bottom panel...remove them,,always unplug first...and you will see your pump claen your filter,,ok onthejob,,just screw it out
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader. did a load of laundry and when i went to get it out the rubber seal is all twisted and the wire spring is off
Is it ripped?If not great all you need is to put the boot back on then reattach the band tighten with i believe eitther a 7 milimeter or 1/4 socket then put the hose slot back on and then the front of the boot following the otther band
Jan 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool WFW9500TC Front Load Stacked Washer / Dryer Logo
98 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
