Question about Kaito KA1103 SW/FM/AM Radio
Same problem with volume control
I need to replace the volume control .
what type or what rating do I need .
Can somebody help.
  • hdob Sep 14, 2009
    What i need is the type or the value of the device so that I can replace it
I had this problem. The jog dial just stopped functioning. I repaired it by doing this:
1. Remove the batteries and leave the battery cover off.
2. Remove the case screws from the radio using a jewelers sized Phillips screw driver. There is one screw inside the battery compartment.
3. Gently separate the two halves of the radio just a few inches. Remove the wrist strap; it will just be laying over top of a screw post.
4. Inspect the wring of the jog dial. You will note several wires soldered to the dial, including one small bundle of wires leading from the jog dial to a white plastic connector on the faceplate of the radio.
5. Study the bundle of wires from the jog dial to the faceplate. Is it twisted? Has it been crimped inside the case? Smooth and straighten the wires with your fingers gently. Remove severe bends.
6. Detach the small white plastic connector from the faceplate and untwist and smooth the wires. The connector should slip off easily. Now clean the metal pins that the connector mates to with a Q-Tip. Seat, remove and re-seat the connector 3 times to scrape off any built up corrosion. Ensure the wire bundle is smooth and untwisted and reattach the connector.
7. With the radio still apart, reinstall good batteries. DO NOT USE AC POWER! and check that you have returned the proper function of the jog dial.
8. Reinstall the wrist strap over the top corner post and carefully mate the two halves of the radio together. Continue to test and check the jog dial as you seat the halves together. Reinstall one or two case screws at a time, checking that the dial still functions until the radio is fully reassembled and the case is tight.
Posted on Sep 12, 2009
Can you adjust the sound for headphones
The volume control usually does not adjust the headphone volume just the speakers. Radio Shack carries an several types of inline volume controls that should work for you such as the following:
http://www.radioshack.com/product/index.jsp?productId=2102975
and
http://www.radioshack.com/product/index.jsp?productId=2272471
They carry them in stock at most stores.
I hope this helps you, if so please rate my solution.
BuddyMc
May 06, 2011 | Televison & Video
What does the check engine code p0406 mean on my dodge caravan with a 3.3L engine?
P0406 - Exhaust Gas Recirculation Sensor A Circuit High
An improper voltage signal is sent to ECM through the valve
Early Models : The EGR valve control the amount of exhaust gas routed to the intake manifold. Vacuum is applied to the EGR valve in response to the throttle opening. The vacuum control the movement of the taper valve connected to the vacuum diaphragm in the EGR valve.
Late Models : The EGR volume control valve uses a step motor to control the flow rate of EGR from exhaust manifold. This motor has four winding phases. It operates according to the output pulse signal of the ECM. Two windings are turned ON and OFF in sequence. Each time an ON pulse is issued, the valve opens or closes, changing the flow rate. When no change in the flow rate is needed, the ECM does not issue the pulse signal. A certain voltage signal is issued so that the valve remains at that particular opening.
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Engine hesitation
Possible causes
- Harness or connectors (EGR volume control valve circuit is open or shorted.)
- EGR volume control solenoid valve
- EGR temperature sensor and circuit
Possible solution
- Repair EGR harness or connector
- Replaced EGR volume control solenoid valve
- Replaced EGR volume control valve
Hope helps (remember to rate and comment this answer).
Mar 31, 2011 | Dodge Caravan Cars & Trucks
I have a passat 3.6 2006 that is driving me crazy whith the volume that i cannot control as i would like to.I already have deactived the speed control and that problem still there,if want the volume high...
The radio's in most VW's are fickle. You basically need a new unit. Whatever you do ,do not buy one from the Dealer. Any other models are cheaper and will last and work better than the factory unit.
Jun 23, 2010 | 2006 Volkswagen Passat
Sansui AU-7500 volume control problem - need replacement
Hi...
Is that the fancy pot with more than 6 leads..kinda square looking?
This place has some.
http://angela.com/
Rate my help if this helps...Thanks
Mar 11, 2010 | Audio Players & Recorders
Every things works fine in nokia e71 but when somebody call me or i call somebody i can,t hear their volume loudly.....so plz tell me how i increase their volume..the volme level is max ...is there any way...
While you are talking press the up arrow or check side of phone for 2 buttons that control volume up and down. Most phones you can press up on the center square or up arrow.
Nov 12, 2009 | Nokia E71 Smartphone
I have c903 sony ericsson when somebody calls i can not hear them but they can hear me how can i fix the problem
on the main standby screen type ->*<-<-*<-*<-* here -> means right joystick button and <- means left joystick button, don't meter if the menu opens after first click u continue typing. then go to the service tests, you can increase the volume here and go to that tests menu and then speaker test and follow the instructions if u don't hear anything then your speaker is faulty so get it replaced by a technician, your problem will be solved! reply and revert back for more support and ratings!
Oct 14, 2009 | Sony Ericsson T230
Yamaha YST-MS50...how does it work ??
I have a YST-MS30 myself. Judging by Yamaha's site, the MS50 looks like it's built pretty much the same way. The subwoofer by itself is pretty useless. The power switch and volume controls are built into the right satellite speaker. There is a level control for the subwoofer, but overall system volume is controlled by the satellite speaker. You also need the power supply (15 volts, 1.2 amps for the MS30, but probably different ratings for the MS50 with its higher power).
Actually, it would be possible to open the subwoofer and puzzle out which pins in the connector you would need to jumper together to turn it on, and you might be able to find a suitable power supply. But it seems like more trouble than it's worth. Complete new system with comparable specs are around $100 from online vendors.
May 02, 2009 | Computers & Internet
Yamaha RX-V800 volume knob on receiver not working.
It sounds like the volume control pod has gone bad and needs replaced (The knob shaft connects to the pod main body and the inside of the volume pod is what controls the rate of volume,If the inside becomes worn ,broken or dirty the volume will become erratic) Replace volume pod ! ..You may try cleaning by taking off the volume knob and getting a can of pressure air and blowing the dust out!
Please rate response!!
Jan 06, 2009 | Yamaha RX-V800 Receiver
The volume
There might be number of reasons
1) check your sound drivers are good. Start-->run--> type devmgmt.msc and check if u can see any yellow mark on sound devices
2) in control panel go to volume control and check if wave bar in not at bootom or mute button is not checked.
3) Go to start-->run--> type services.msc, check in windows audio if service is not stopped if its is then restart this service.
Hope it helps !!
Please rate my answer
Oct 02, 2008 | IBM ThinkPad R31 2656 Notebook
Problem in audio drivers in pc
I'll need more info on this problem: what type of connection do the headphones use? USB? Bluetooth? Classic audio jack?
Solution bellow applies in case of "ordinary" audio jack headphones. Also, check if your headphones have a built-in volume control (usually located on the cable). If that is the case, look for a Microphone On/Off switch if one exists.
Step 1.
Make sure that you've plugged in your headphones in the correct jack. These days, they are usually color-coded so Microphone should go be plugged into a red jack.
Step 2. Run "Volume control ["Start > All Programs > Accessories > Entertainment >Volume Control"] or double click the speaker icon in your System Tray if it's present.
Step 3. In Volume Control, activate "Options > Properties". Find "Microphone" and "Line In" under the "Show the following volume controls:" and activate them. Click ok.
Step 4. Maximize the volume on the "Microphone" and "Line In" slider.
Hope it helps. Rate me. Thanks.
Feb 17, 2008 | Audio Players & Recorders
Kaito KA1103 SW/FM/AM Radio Logo
183 people viewed this question
Top Kaito Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Kaito Audio Player and Recorder Expert? Answer questions, earn points and help others
