Question about Garmin Nuvi40lm Nuvi 40lm Lower 48 Gps Travel 010-00990-21
How do you calibrate Nuvi 40LM when the calibration is so badly off?
The calibration is so badly off that when I hold my finger down on Top left hand side it sets off the search option
  • Garmin Master
  • 2,130 Answers
Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Posted on Oct 17, 2016
SOURCE: Screen Calibration problem with SteetPilot c330
Turn off the unit. Then hold down the power button for about 1 minute and the calibration screen will eventually come up.
Posted on Oct 13, 2008
sharcnet
  • 2130 Answers
SOURCE: Nuvi 680 touch screen problems
If you keep holding the button down it will go past the pre-boot mode and you'll eventually come to the calibration screen. Please see this link for more info:
http://www.sharc.net/discus/messages/6/77.html?1236709210
Also see this link on how to het your touchscreen replaced:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Jul 13, 2009
sharcnet
  • 2130 Answers
SOURCE: Cant calibrate my Garmin Nuvi 255 GPS
You have the wrong procedure. Please see this link:
- Jim
Posted on Dec 20, 2009
sharcnet
  • 2130 Answers
SOURCE: Failed to calibrate keyboard of my Nuvi 205w
Please see this page for recalibration procedure. If that doesn't work, then then the touchscreen needs to be replaced.
- Jim
Posted on Dec 30, 2009
  • 343 Answers
SOURCE: my garmin nuvi 1350 LMT
There should be a black dot to press on the calibration screen. Keep pressing the dot as it moves around the screen, you may need to press very firmly and use a stylus until it says calibration complete.
This usually occurs when a unit is dropped or left in extreme temperatures or jammed it a glove box or console with things jammed against the screen. It could also occur if you are touching the screen as you start.
Thanks for using FixYa
Posted on Jul 27, 2011
How do I fix when I touch a key to put in information and it prints a different number or letter than the one touched
Here is a way to recalibrate the touchscreen without having to go through the menus:
If your Nuvi has the problem that when you press one key but another key is highlighted, then either your touchscreen is defective or it is miscalibrated.
For example, pressing the letter "A" on the QWERTY keypad, actually highlights the letter "S" or "Q" or "Z". On the non-QWERTY keypad, this may show up as "B".
Method #1: If you can get to the main menu, press the "wrench/tools" icon and then the "Display" icon. Now press the calibrate screen button and go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Method # 2: Follow this procedure if you can't get to the main menu or any menu thereafter.
First, turn the unit OFF.
Nuvi 3xx & 6xx Series: Hold down the on/off power button and don't let go of it.
On the screen it will say "Pre-boot mode"..... keep holding the button down..... after some time you will eventually come to a screen with dots. If the screen says "Loading" and does not go to to the calibration screen with the dots, you will need to connect the Nuvi to a PC with a USB cable and rename the file "GUPDATE.GCD" within the Garmin directory to "GUPDATE.OLD". Once the file has been renamed, repeat the above procedure.
Once you reach the calibration screen, now you can let off of the on/off power button. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Nuvi 2xx/2xxW Series: Turn the Nuvi off. Place your finger on the upper left-hand corner of the screen and then slide the on/off power switch to the left and hold until you see the calibration screen. Note: Some 2xxW models require the procedure below for the 7xx.
Nuvi 7xx Series: Turn the Nuvi off. Touch the screen anywhere and keep your finger there while moving the on/off switch to left (don't wait for Garmin logo to come up) and then quickly moving the switch the right (lock position). After a short while, you will reach the calibration screen. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Nuvi 8xx Series: Turn the Nuvi off. Remove the battery from the Nuvi for at least 10 seconds. Press and hold your finger on screen, while putting the battery back in. The Nuvi will boot-up and you should see the text "Pre-boot Mode" appear on the screen. Continue pressing on the screen until pre-boot goes away and the progress bar appears. Now remove your finger. After a short while, you will reach the calibration screen. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Nuvi 11xx, 12xx, 13xx, 14xx, 16xx, 24xx, 25xx Series: Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Once completed the Nuvi will display Calibration Complete
This will recalibrate your touchscreen to the LCD display.
If this doesn't resolves your problem. then your touchscreen may be defective.
Oct 10, 2015 | Garmin Nuvi 1350LMT
Can not get password to use on iPad or iPhone to work using password
If you are asking about the passcode that locks your iPad or iPhone so others can not access it, following the steps below.
-Start with the iPad screen off.
-Press the HOME button (the small circular button close to the screen)
-Slide to unlock the screen, at the bottom.
-Press the HOME button until you see a box that says SEARCH IPAD (the keyboard will also slide up when you're on the correct screen)
-In the box that says SEARCH IPAD, type SETTINGS
-At the top of the list, created by typing SETTINGS, should be the TOP HIT of SETTINGS.
-Select SETTINGS by tapping with your finger.This will open the SETTINGS app.
-On the left hand side of the two columns, in the SETTINGS app, should be a list of options. Select the GENERAL option from the list by tapping it with your finger.
-On the right hand side of the columns should now be a list of more options starting with ABOUT.
-Continuing looking down past the ABOUT option for the option PASSCODE LOCK.
-Select the PASSCODE LOCK option by tapping it with your finger.
-A new menu, on the right hand side, should now appear starting with the TURN PASSCODE ON option.
-Select the TURN PASSCODE ON option by tapping it with your finger.
-The SET PASSCODE pad should appear in the center of your screen. Enter a four digit passcode of your choice.
-Reenter the passcode you chose again.
-You are done! The next time your iPad times out or you lock the screen, it will require the four digit passcode you set by following the above steps.
Oct 19, 2012 | Cell Phones
Unable to unlock Nuvi 780 screen. The slideing button on the top left dosen't work, it lost the grip and just move on either direction with out any action. Please help
Try to remove the battery and re insert it back in to see if it will work. Or hold down the power on/off for about 15 seconds, that should do the job.
If that does not do it, then you have to calibrate the screen. To calibrate the screen, follow the steps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi.
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears(white screen with touch dot),
  5. Then follow the on screen instructions.
That should do the job for you. hope this helps.
Dec 24, 2010 | Garmin nuvi 780 GPS
Friend has a problem with his Garmin nuvi: when typing the letter to the left appears. what can be done?
It needs to be calibrated
To calibrate the touchscreen on your nuvi 200W follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To calibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
Aug 14, 2010 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 1350:touch screen calibration
Hold your finger on the top left corner of the screen while turning it on. Release the power button when you see the Garmin logo pop up but keep your finger on the top left corner until the white calibration screen shows.
Apr 09, 2010 | Garmin nuvi 1350 Car GPS Receiver
Trying to reset my garmin nuvi 350 but per-boot mode is keeps coming up. i hold down the left corner and hold the power button i don't understand why i can't reset it. HELP im going nuts
(G-Brand): Place your finger over the lower left-hand corner of the screen (upper left-hand corner for a 6xx series) and hold it there while pressing the on/off power button. Keep holding your finger there and a window should pop up asking if you want to go into maintenance mode. Select yes. There is an option called "clear user data". Select that option. It will not erase your favorites. It will however, erase any corrupted satellite data and will default you back to some factory settings and to a location of the manufacturer's headquarters in Kansas. This will also force your GPS to collect new satellite data. Your GPS should reboot and it will ask you a couple questions like, timezone, language. Please select the proper settings.
- Jim
SHARCNET-USA
Dec 10, 2009 | Garmin Nuvi 350 Car GPS Receiver
- Jim
SHARCNET-USA
Dec 10, 2009 | Garmin nuvi 200W GPS
How dp you alter the time of the hands
  1. Press the Bottom Left side button until you reach time keeping mode.
  2. Press the Bottom Left side button 6 times to reach hand setting mode.
  3. Hold down the Top Left side button until the digital time starts to flash.
  4. Press the Bottom Right side button to advance the analog time by 20 seconds; Holding the button down will advance the time faster. Pressing both of the Right side buttons will lock the time into advancing quickly without holding buttons down; this will continue until you press a button or the clock advances 12 hours.
  5. Press the Top Left side button to exit the settings screen.
  6. Press the Bottom Left side button to return to timekeeping mode.
Mar 12, 2009 | Casio Watches
I can't even set my Casio Marine Gear watch.
Go to this link and with the four digit module code from the back of the watch you should be able to get a manual; http://world.casio.com/wat/download/en/manual/ Hope this helps :)
Jan 15, 2007 | Casio Marine Gear MTD1042A-2AV Wrist Watch
Garmin Nuvi40lm Nuvi 40lm Lower 48 Gps Travel 010-00990-21 Logo
305 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
