Only has Uniden DECT 6.0 on phone
SOURCE: want to put a new message for the greeting
Here's a link to Uniden's download page:
http://www.uniden.com/index/manuals_results.cfm?cat=1
Your model is listed there. Just download yourself a copy and you'll have all the answers (and you won't be able to lose it again)!
SOURCE: i have a uniden answering machine and i want to change the
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
i downloaded the owners manual from uniden at the link above , and from what i see its on page 26 of this pdf manual ,
enter the answer set up menu , and then the ring time sub menu , press volume up / down to select a ring time ( toll saver , 2 times , 4 times or 6 times ) then press the "OK" soft key , you will hear a confirmation tone . good luck
SOURCE: how to check messages over phone outside of house
You didn’t post which model you have, but this should work. If it doesn't, post which model you have and I can give you different instructions for your specific model.
To operate from a remote location, use any touch-tone telephone, and follow these steps:
Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about ten rings and sounds a series of beeps.
During the greeting or the beeps (if answering system is off), press [0] and enter your security code/PIN within two seconds (The default security PIN is 80)
The answering system announces the current time and the number of messages stored in memory..
You hear “To play incoming messages, press zero-two. For help, press one-zero” followed by a beep.
SOURCE: "i have a uniden 6 0 dect2080 3 answering machine how to check the messages from a different phone"
The default security code is "80". If you have not reset that code, you will use 80.
This is all from the manual:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about ten rings and sounds a series of beeps.
2) During the greeting or the beeps (if answering system is off), press 0 (zero) and enter your security code within 2 seconds.
3) The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero" followed by a beep.
Then the manual lists all the remote commands. If you need those, you can go to uniden.com and download a manual.
SOURCE: I need an Uniden phone DECT2080 owner's manual.
You can find the manual here:
http://www.uniden.com/pdf/DECT2080om.pdf
