Question about Casio EXILIM Card EX-S770 Digital Camera
Camera wont turn on.
It would not turn on or charge but can show picture show on cradle. i have bought a new battery but this dosnt charge either ???? please help.
  • 744 Answers
Hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Posted on Jul 18, 2009
It wont turn on i even bought a new batery and still nothing what could it be?
Is your new battery charged? You may need to place it in the charger or hook the camera to the AC power and leave it overnight. If you have a charging cradle try to charge the battery that way. Sometimes that arrive dead.
Dec 14, 2010 | Canon ZR200 Mini DV Digital Camcorder
My casio ex s880 won't turn on. when i put it on the charger cradle the red light flashes (it normally doesn't flash). Also when its on the charger it'll let me view my pictures on my memory card it just...
It happened to me. I fixed it by luck . Here is my way . fully charge the camera till the led turns green. "IMPORTANT" unplug the power of the charger first, then remove the camera from the cradle . Then I pressed power button, it worked.
Wish good luck to you too
cz
Jul 18, 2009 | Casio Exilim EX-S880 Digital Camera
Casio Exilim works on cradle, wont turn on when off cradle
I would guess that the battery is not being charged. The problem could be poor connections between the charger & Camera or between camera and battery; or the battery no longer will take a charge.
First, clean the connections with the eraser end of a pencil. Clean the connections on the Charger and on the camer; clean the battery connections and in the camera, Charge overnight. If this does not get the camera working, borrow a battery and see if this works.
Jun 22, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Battery charging
I had the same problem, called Casio, and -- like the first solution -- they'll send a battery.  So, folks, it's a manufacturer-originated problem and kudos to Casio for owning up to it (they admitted it on the phone) and for sending the solution, a replacement battery.
Dec 23, 2008 | Casio Exilim EX-S880 Digital Camera
Camera Won't Charge
my finepixz3 got wet. but after a few days it worked! but when the battery ran out it wont charge. is it the battery? it turned on a few sec when its in the cradle but it wont last after a few seconds it would turned off. is it the battery or the camera itself?
Sep 01, 2008 | Fuji FinePix Z3 Digital Camera
Wont turn on
same here. i think it is an issue with the dock that it has to sit in to do anything. I'll never buy another camera that has to sit in a dock to charge and/ or load pictures.
Jul 18, 2008 | Casio Exilim EX-Z40 Digital Camera
Battery charging
i have not used my camera since June, when i went to charge the battery the other night the Red light just kept flashing even after leaving it for 8 hours, i can get pictures from it which are stored in it but the shutter will not open whilist in and out of the cradle.
May 28, 2008 | Casio Exilim EX-S880 Digital Camera
Fuji finepix f401
I had a similar issue, and also bought a new NP60 battery, to no avail. Then I dismantled the cradle, and found a fuse on the circuit board (F01 label) which showed open. I soldered a bit of 5amp fuse wire across the top of it, and everything came back to life.
DISCLAIMER - 5amp wire was the smallest I could find. I don't know what it's meant to be. I also don't know why the original fuse blew, which means that my camera probably has another fault somewhere. However, It's been working fine for over 3 months since then.
Nov 21, 2007 | Fuji FinePix F401 Digital Camera
Camera Wont turn On: Is it stuck in USB mode? How do i fix it?
I was able to get past this problem by removing and reinserting the battery. This caused, in effect, a hard reset of the camera, which let me power it up fresh and take pictures again. Of course, it's not exactly reassuring that the problem arose in the first place,
Jimmo
Nov 04, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Rechargeable Battery won't charge
I think this is a general Fuji design fault in the camera circuitry. I have an older F455 which has exactly the same problem and I did the same - bought new batteries only to discover that didn't help. The only solution is to spend even more money for a stand alone battery charger.
Sep 07, 2006 | Fuji FinePix A340 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
252 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
