Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus 7-Cycle Gas Dryer - White
The heat on our 2 year old Cabrio dryer just stopped working for no apparent reason. Everything but the heat appears to be functioning normally. Help!
    President:
  • 1,714 Answers
Thermostat controls heat. There is also a motor centrifugal switch, in the element circuit, that the motor closes to insure the motor is turning. Try another heat setting. There is more than one thermostat. You may have blown the 'thermal fuse' too, which requires replacement.
It is possible that your element has failed also.
Tripped high limit. Must clean the lint filter and the exhaust vent tube and all the way in to the dryer. Hot air exit is restricted.
Posted on Jul 18, 2009
Why would check vent light go on after replacing sensor and computer
Is the dryer vent blocked with lint? If there is a restriction in air flow in the vent system, the dryer will stop. Make sure the vent path is completely clean even in the wall where the vent hose connects.
Oct 07, 2016 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Cabrio model WGD6400SW gas dryer runs but not heating at all. have cleaned it.. still no heat. This happened the same day we had a service tech look at our cabrio washer. Have not had them for 3.5 yrs...
I agree. It's rotten to have someone check out your product and then have it stop working. You probably have a problem with your ignition panel.This is the part of gas dryers that gets hot. When it reaches a certain temperature it causes the pilot light to ignite. It sounds as if your ignition needs to be replaced. We did this and had another 6 years from our gas dryer.
If you're handy you can probably do this replacement yourself. If you're like my spouse and me, we found a reasonably priced professional who completed it in just a few minutes.
Good luck. I hope this helps you. If it does, please come back to Fixya and rate my help!
Jul 31, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Cabrio not heating. Its about 2 years old. Is it
It is probably your T-stat, its abotu 10 to 15 bucks at the car part store.
Nov 27, 2009 | Dryers
Dryer will not heating up. Only 5 years old
Two possible reasons:
1. The heating element or the temperature sensor is broken.
2. The exhaust vent is obstructed and needs to be cleaned.
Good luck.
Oct 01, 2009 | Frigidaire GLET1041A Top Load Stacked...
NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
May 29, 2009 | Whirlpool GEW9250 Electric Dryer
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
GE Dryer
Sounds like an intermittant break in the heat element. Could also be an irratic control thermostat or bad connection somewhere between the line and the heater. Simple to isolate with a tester.
Jan 04, 2008 | GE DCSR483EA Electric Dryer
3 1/2 year old Whirlpool Duet Dryer stopped heating up
it could be several things but the element could should be the last part i would check first if you are still using fuses change them both if that doesnt work call for service call a good service man stay away from major companies they are expensive i know i worked for most of them
Nov 22, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus 7-Cycle Gas Dryer - White Logo
381 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
