First I want to say I do not have the best writing skills so please look past the lack of punctuation and possible spelling errors with that said I'll give my answer .
I have seen and repaired this problem manny times in manny different brands of tvs including most if not all the so called reputable brands, and I don't recall it ever being any of the boards as mentioned in the answers above. For tv's that use led 's for the back lights I have found that the back lights will fail to turn on at all or flash on once briefly when the Set is powered on. I have found most cases this is caused by a single led that has burnt on one of the led strips inside the TV . The led backlighting basically works the same as Christmas lights do any time a single light burns out the whole stran goes out and you have to find and replace the bad light to fix the issue you can replace a single led but it requires some advanced soldering skills . You can order a new led strip and replace the bad strip locating the bad strip you need a digital volt meeter and look up how to test led with a volt meeter . I hope this answer will help others that experience this problem
Replace the TV, fixing it is very expensive and then shortly after another problem will occur. It soon becomes a money pit. The backlight and driver board is about $400.00 just for parts.
Perhaps the backlight LED driver board needs to re-seated.
Also check flex wire connectors for loose connection.
reseat or replace
Don't waste any money on this poor quality TV. The backlight is not working and can't be easily replaced without a new LCD panel, which is too expensive a repair. Stick to reputable brands/manufacturers when buying TVs.
SOURCE: We have a Hisense 50h5g 2014 model , The tv has sound but no picture ,
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
