Question about Epson Stylus DX6050 All-In-One InkJet Printer
Run our color ink can i print black only on my EpsonBX300F PRINTER and How???
  • 805 Answers
Ya ur document convert grey color and then when print command then see printing preference and setting grey color
Posted on Jul 18, 2009
I have a all in one color LC61 printer, do all colors have to be filled to print blk only?
Greyscale is color not black only.
You can print in black and it will look grayscale only darker, printers are a pain to work with after a year has gone by, I can expect almost a half hour to print something with my $400 epson because one of the colors is out even though I never printed in the last year a colored page. I take the color cartirges out and they are empty, but I only print a page 2-3 times a year. I use the scanner all the time. Brother and epson have their print heads in the printer not the cartridge so make sure your inks are always have something in it or it will be miricle for the printer to last more than a year. Check colors every other week. One Epson printer only lasted 3 months because I never used it(print head dried up). Never use the set up with tubes running outside printer to small tanks of ink if you only use it occationally.
May 11, 2014 | Unknown 10pk 4B,2C,2M,2Y Compatible LC61...
Brother MFC-290c printer does not print black anymore. Test print page color ok but not black printing. What is the problem?
The problem is either:
* out of BLACK ink -- replace the ink-cartridge
* clogged ink-jets -- the ink is not spraying onto the paper, so run a few print-head-cleaning cycles
* dead electronics -- not triggering the jets to spray ink, so replace the printer
Feb 20, 2011 | Brother MFC-290C Multifunction Color...
If the black ink runs out does the printer automatically use color ink to print black?
Hi. When you are printing in black but "black and white" is not selected in the printer "properties", the printer will use some of your colored ink to print grays. If the black ink goes out, it will give you an error and will not print using colored ink even if you are printing black only. Hope this helps.
Feb 03, 2011 | Canon PIXMA MP210 InkJet Printer
Black color will not print. Installed a new black
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any inkjet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Dec 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have run out of color ink want to print with black only
all you want to do is to remove the color cartridge then that's it you can now print in color balck
Jan 07, 2010 | Canon PIXMA MX310 All-In-One Printer
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
Question about ink cartridges
The printer will take a little quantity of color ink though you are printing in black in order to get good quality. Hence it is not possible to print with just black ink cartridge without color cartridge.
Thank you.
Dec 06, 2008 | Compaq A3000 All-In-One InkJet Printer
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
PRINT IN BLACK WITH COLOR CARTRIDGE?
Yes, you can print out in black from a color cartridge, however it is not advised as you will run out of colored ink twice as fast as it combines all the colors to get black.However it works great when your in a pinch and need black ink.
Just go to your printer properties when you print and the option will be in there someware.
Dec 26, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
Epson Stylus DX6050 All-In-One InkJet Printer Logo
121 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
