Question about Samsung HLN467W 46" Rear Projection HDTV
No picture no sound
Lamp light comes on. Unit tries to start (3) attempts then (3) flashing lights. Will not shut off by power button.
  • 111 Answers
This is most often caused by a faulty lamp or faulty ballast. try resetting the tv by unplugging and leaving it unplugged for 5-10 minutes or so, plug it back in and check it.
you should be able to find the replacement parts via
ballast is part number BP4700017A
lamp is part number
compatible cheaper lamp part number
hope this helps,
Posted on Nov 19, 2007
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
Pix shuts off, green light starts flashing, pix comes back and shuts off again
If you have an issue where your picture turns off and the green power light starts flashing, you are most likely looking at a weak or old lamp. Do not be confused with a pix loss and a RED light flashing, as this can be caused by many things. The normal sequence of events for this fix is this:
1) TV turns on normally, plays for 1 to 3 minutes (may be more or less time)
2) Picture goes out and green power light begins flashing. It may flash for up to 2 minutes
3) green light turns on solid (stops flashing) and picture returns.
4) Picture goes out again and process repeats.
You may have been told that "if the lamp light isn't on, it isn't a bad lamp".
A weak lamp will cause the process above to occur. Other signs of a weak lamp:
The reflector in the lamp is very cloudy
You may see a "growth" or "bubble" on the vertical glass tube which is the lamp
You haven't replaced the lamp in quite some time or it is the original lamp from when you purchased the TV.
In cases like these, try a new lamp. Stick with an original Sony lamp, as there are many stories (both personally witnessed by me and also documented on the web) about problems with after market replacement lamps. And remember, lamps DO NOT have a shelf life; you can store them in a good environment (not too hot or cold!) for an indefinite period with no ill effects.
on Nov 03, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
No picture, no sound, power button blinks 47 times, then lamp flashes 134 times, then shuts off
It is symptom of weak Lamp in your TV, replace Lamp with following part number..
A1606034B LAMP BLOCK XL-2100U
It is available in Sony Accessories for $200
Always buy Sony Original Lamp for your Sony TV and avoid aftermarket/ cheap lamps.
Apr 22, 2009 | Televison & Video
Green light flashing & no picture on Toshiba 40pw13p
There is problem with the lamp. It might need to be replaced. The lamp unit is on the bottom-left side of your TV. Loosen thumb screw (by hand) to take the the lamp unit door. Using a screwdriver, loosen two screws of the lamp unit and carefully pull the lamp unit out.
Put a new lamp in reverse order.
Jun 28, 2008 | Televison & Video
Blue screen with Green Star-burst image in center?
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
No picture, won't turn off
the noise you hear after the melody would you describe it as like a buzz or a small chainsaw? If so you have a bad color wheel assembly. If the noise is intermittent than your issue could be the ballast that controls the lamp. If you've already changed the lamp the next step should be the ballast.
Dec 03, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Dlp tv will not "fire up"
if your tv is on warranty take it back to the supplier.the problem with your tv is in the power supply there is a open regulator in that circuit along with the H .O. Transistor there is a black that feeds from the HOT to the flyback which also needs to check probably it is also open.good luck my friend
May 06, 2007 | Samsung DLP HL-P5663W 56" TV
PT-45LC12 wont power up
You have a bad lamp. The "clicking" sound you hear is the ballast (lamp power supply) attempting to start the lamp. The warning on Panasonics that comes up on screen does so when the life expectancy of the lamp is approaching. Otherwise your "clicking" sound and the red light on front are saying bad lamp. When you replace the lamp remeber to follow the instruction that Panasinc provides with the new lamp on restetting the lamp timer. This is usually done with the volume down on the TV and the PIP button on the remote.
Feb 26, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Samsung HLN467W 46" Rear Projection HDTV Logo
85 people viewed this question
Jerry Greenberg
Jerry Greenberg
