Question about Refrigerators
The sandstrom fridge freezer model sff4ds11 not working
Stopped working
    Top Expert:
  • Refrigerators Master
  • 10,321 Answers
Check compressor and start up capacitor
Posted on Sep 01, 2018
SOURCE:
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
22yooper
  • 828 Answers
SOURCE: Fridge stopped working, freezer still works
Light going out is a separate problem. If the freezer is still working and the fan in the freezer operating check for frost on the back wall. If there is frost on the back wall you have a defrost system problem.
Possible open heater, bad timer, or defrost thermostat. If the freezer is not working check for power to it. Reset the breaker if necessary.
If the light went out because of some power loss the freezer would not be working.
Posted on May 26, 2008
  • 161 Answers
SOURCE: I have an Amana bottom
If the coils were really dirty, the compressor is probably just overheated. Let it cool down overnight then try again. If it still won't stay running it needs serviced. Could be the start relay or internal overload/overheat sensor in the compressor. If the coils were really dirty and it was used like this for a long time, the compressor could be damaged. It is almost never worth replacing a compressor in a home refrigerator.
Posted on Jul 03, 2008
peyton32034
  • 410 Answers
SOURCE: Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Posted on Jan 21, 2009
  • 219 Answers
SOURCE: Fridge on Zanussi ZX56SI has stopped working but freezer fine
check in your frezzer on the back wall if its all frosted up u have a defrost problem u can unplug and let thaw fgor 4 or 5 hrs plug back in and wilkl work till u can have it serviced if no frost u might a bad fan or a damper control
Posted on Mar 19, 2009
My Sandstrom SFF4DS11 blew its plug fuse and when I replaced it blew the fuse on the pcb. Do you think this is likely to be a fault in a pcb component?
Chances are you have some shorted diodes in the power supply circuit, don't replace the fuses again before replacing the bad components
Mar 30, 2018 | Televison & Video
Fridge part of fridge freezer stopped working
Please add the make and model of your fridge. Is it frost free or not?
Jan 06, 2014 | Beko Refrigerators
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Bottom freezer not working
Hi, sorry I do not have any advice to offer. We have the same model. Three weeks ago the red light came on and freezer stopped working. Last week the fridge packed up. We may have been unlucky but I thought it might be worth mentioning incase they were related and your fridge gave up as well.
Jul 06, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
194 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
