Question about Linksys Computers & Internet
Linksys~ During the installation process of the Epson printer installed on our home network system; there has been an unexplained operation performed by us that now has us locked out of our home network. We are using the initial password assign at the time of installation. The network will not accept this password & we are locked out of our home network on our wireless devices such as our I Pod & my laptop (which is wireless capable). I do not know how to reset the password, nor try to create a new network. Unfortunately we don't have the original installation disk. Can you pls assist? Thanks Rhett Kirby
  • seek_gods_ki Jul 18, 2009
    Thanks for the reset button. Couple of questions. I understand that we many not need the disk to re-intall, can you give a ball park figure as too the cost of the downloads? In order to create a new network I can do that process through the Network & Sharing Center, correct? It is best to select to select a "private" network? Model # Linksys WRT54GS. Operating sys Vista.
    Thank You
    bvanjoff
    Once the router is reset back to factory settings I will then need to re-establish the 2 computers, the printer, the laptop, & the ipod manually. Is that right? Are there instructions for that as well. We don't have any of the manuals for any of our computers. 2 Yrs old. Just didnt keep then. Pls advise.......
    Genius:
  • 1,043 Answers
On the back of your Linksys router there is a reset button. Press this for 10 seconds. This will reset your router back to the factory default state as it was when it first came out of the box. The password for the router will be reset as well. You do not mention what your model number is but the majority of the Linksys routers come with no default password. You can then set it to whatever you choose to use. You will then have to setup your network again. You should be able to setup the network without having to install any extra software. However, if there was anything in particular that you needed from the install cd you can download the files from the Linksys site. Choose the Support item at the top of the page. You will then be given a page with a box that you can fill with either the model number or serial number of your router. The site will then direct you to the models main page. There you can find all of the software as well as copies of the manual. Hope all goes well for you. Here is the URL for their Support page =>
http://www.linksysbycisco.com/CA/en/support
Posted on Jul 18, 2009
  • 4 more comments
  • bvanjoff Jul 18, 2009
    If a blank password doesn't work you can try admin as the password.
    On the bottom of your router will be a black & white sticker. It will have your model number followed by ver.#? What is the number after ver? Also you do not have to pay to download the manual or any of the software for the router.
    Yes you will be using the Network & Sharing center. Or you can use your Help & Support center in Vista and do a search for Setting up a wireless network. Vista have a built in helper that will make it a lot easier to setup your network. It will also advise you of the best way to setup your network. You shouldn't need to have your computer's manuals to setup the network.
    As far as setting up your computers, printers, and Ipods; If you have your router manual handy use it in conjunction with your Vista instructions for setting up your hardware. I've never setup a network for an iPod, but if you're not sure how to do it there should be help on the Apple site. You should be able to get everything up and running without a problem by following Vista's instructions as well as the manual for the router.
  • bvanjoff Jul 19, 2009
    When you have the opportunity could you please give my answer a rating?
    We use the rating system to gauge our effectiveness. Should you ever
    have problems with anything in the future please don't hesitate to use
    our services again.
  • bvanjoff Jul 20, 2009
    I apologize for the delay in answering your last question. It's been a rather busy weekend. Once you do the reset it will wipe out all of the settings that you had added to your router. Most routers allow you to backup your settings to your hard drive to make restoring your network easier. Unfortunately this feature is not built into your router. However, the setup for wireless networks that is built into the Windows operating systems will make things a lot easier when you are reestablishing your network. If your not familiar with the process of adding any computers to your network that are not wireless you can do a search in Windows Help & Support for home network. Both XP & Vista have built in wizards that will make it very easy to add these computers to your routers network. Follow the instructions in the Router manual for the initial router setup. It will make the connection to your Internet connection. Then just follow the manual for setting up your DHCP server. This is the feature that allows the router to give out IP addresses automatically to any item that is a part of your network. The setup for any wireless items is relatively simple as well. Wireless items will either automatically search for wireless networks and then ask you of you want to join them. Or they allow you to manually enter the settings into the router. I haven't ever added an iPod to a network, but I've taken a quick look at some manuals. You would go to Settings and then WiFi Settings. The iPod then looks for wireless networks and asks if you want to join them. It will ask you for the networks password, then choose Join.
    This info should help you to get your network back up and running. Of course if you do run into any other problems please don't hesitate to let me know.
  • bvanjoff Jul 24, 2009
    As long as you do not have any further questions, and when you have the opportunity could you please give my answer a rating?
    our services again.
How to install epson l210 printer on windows 7 correctly?
go to add printer wizard,select windows update option,this take few minutes according to your internet connection,after it select your printer model and and after installing check if there is another printer installed in your devices folder,uninstall all unnecessary printers.
Apr 24, 2015 | Epson L210 - multifunction printer /...
Delete home network defender
Reinstall the software and uncheck Home Network Defender during install.
Oct 06, 2012 | Linksys WRT160N Wireless Router
I have no disc for my new epson sx115 so it won't install into my pc. i tried downloading the drivers from the net but no luck so far .... hpoe ya can help me
Click HERE - download the software and it will work for you as this is the same as a disk. Be sure to download the support software/drive for the operating system you have. - XP - Vista - 7 etc.
Gary @ Fix Ya
Sep 22, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Error 0x000005b3 epson 4200c
Following is the solution for your problem.
Uninstall the printer software after unplugging the printer and remove it from the network , if it in on network.
Download and install the latest drivers from thee Epson webiste for your operating system.
makse sure you are using the admin account to install the software, once installed it will be working fine.
Jul 06, 2011 | Epson CX4200 All-In-One PSC Printer
Hello sir , i have epson stylus cx5500 printer.but i have no installation cd . it's possible to install it trough net?how it should done?
Driver for Epson Stylus CX5500 Printer
Please visit the above link from Epson Official Support and downloads. Select the Operating System you have on you Computer and click search to download the latest drivers.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Feb 10, 2011 | Linksys WPSM54G Print Server
My Epson RX 620 will not print anything from the computer with Vista
Have you tried running a print test page? Have you gone to epson.com website to see if they have printer driver available for your printer...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=44341&infoType=Downloads -
Jun 16, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
M looking for epson stylus 400 printer driver for windows xp. i tries really hard but didn`t find
Necessary you driver are found with system Windows If say in other words, that they already recorded on your hard disk.
System Itself will find them for you during process of the installing the printer.
Exist for Epson Stylus 400 ESC/P2 Also for for Epson Stylus Color 400 ESC/P2 You simply it is necessary to install printer manually through menu
1) Control Panel
2) Printers and faxes
3) Add printer
4) Next, Next, Next
5) you must choose brand "Epson" and your model of printer.
6) Next, Next .............
Good Luck !
Mar 22, 2009 | Epson Office Equipment & Supplies
Installation of cx5500 epson no installatin cd
You can get the software for the Epson Stylus CX5500 from here:
http://tech.epson.com.au/downloads/category.asp?id=styluscx5500&EmailAdd=&CanEmail=&SelOS=Y&MetricIDReturned=2745207&sCategory1=Multi_Functional
Just choose your operating system and press Search, then Continue on the next page.
Fixya!
Chris (ziraffa)
Jan 16, 2009 | Linksys WPSM54G Print Server
How do I connect a laptop to my hp 2575
I would recommend using the built in networking. You can connect your printer to the network, then use the install disk to install it. During the install wizard, make sure to select the option for the networked (TCP/IP) connected printer. You will install the printer seperately on each machine. Alternativly, you can install the printer on one machine and share it across the network. There is a button on the Sharing tab to install additional Drivers. You use this button to install the driver for the other operating system. I hope this helps. Let me know if you need more information.
David
Dec 29, 2008 | HP Photosmart 2575 All-In-One InkJet...
I have an Epson Stylus Photo R220 Printer connected to a linksys print server, but
Well, The first thing you should do is to try to test of the print server is properly connecting to the printer. Check the linksys printserver manual and look for how to print a status sheel from the print server. Once done, get the IP address of the print server. Go to your laptop and navigate to control panel/printer. See if you have the driver installed or download the Vista Drivers from Epson.com/support. During the installation, it will ask you what connection type your computer uses. cancel out of the installation or choose LPT1 as the port. Once done, go back to control panel/printers.Right click the R220 icon and navigate to properties. Select ports after that and add a new port. Select Standard TCP IP port after that. Once done, the wizard will appear. Input the IP address of the printer and finish the wizard. you should be good to go after this.
Sep 30, 2008 | Epson Stylus Photo R220 InkJet Printer
Computers & Internet Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
