Question about Lenovo IdeaPad Y430-3231U Notebook
The Lenovo Y430 occasionally gets a blue screen. OS is Windows XP. The computer is fairly new. Could this be a software problem or a hardware issue? Would an upgrade to Vista solve the problem?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 127 Answers
You are right but you can try this go to start - run type msconfig press enter.disable all start up items except synaptics and wireless if you do see any.reboot your computer.check if it happens.if it does then it`s hard ware problem.could be RAM,graphics card or any other accessory attached to mother board.take care.
Posted on Jul 18, 2009
I want lenovo wirless driver for Y410-7757 model for win 7 32 bit.
From Windows 7 and up, for all hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible (same as not certified by Microsoft from Windows 7 and up) with the new operating systems.
Most things that worked fine with Windows XP and or Vista, can fail with Windows 7 and 8, because the factory that made the hardware in the first place does not ask for certification with Microsoft for their old Hardware. They only spend time and money to get their new hardware certified on the new operating systems. So to make sure your hardware is compatible with the OS. Check the manual and find out, what you have to do so it will work on your computer.
There is no special Lenovo driver, unless the hardware in your laptop is made by Lenovo. In that case the driver will be on your computer after you installed Windows 7. Perhaps you call something a driver but need something else?
Nov 02, 2014 | Lenovo 3000 Y410 Laptop
Blue screen errors on Windows XP
Microsoft no longer provides support for XP as of April 8th 2014.. I recommend you upgrade your OS, as this could be a number of problems related to using an insecure OS....
May 05, 2014 | Microsoft Windows XP Professional With...
Bluescreen is appearing after installing the os
Usual reason for blue screen after OS install is corrupted OS. It might have missed a file while installing or cd had a smudge or scratch on it. It rare occasions it can be hard drive it self. I would try to reload the OS but make sure CD is clean of dirt and scratches. Most times this will resolve issue. Also if you are installing higher version of OS on a pc that had Hardware that does not support new OS version. Like going from XP to Windows Vista or Windows 7. Sometimes you just cant upgrade even by doing new install since not all computer hardware is compatible with new OS. Some manufactures do this so you have to by new computer in order to get new Windows version. Hope this helps.
Nov 06, 2010 | Computers & Internet
For the past few days my Lenovo IdeaPad Y430 has been booting up as usual up to the point where i put in my username and password. I get a black screen with the cursor after i log on and cannot go beyond...
Hi verneaimable,
I'm glad to help you out with the boot up issue of your Ideapad Y430. Based on the details that you have provided this is leading to a software issue. To address this concern, you need to reload the Operating System of your machine. OS has been corrupted causing you not to boot up on Windows. Lenovo do have this One Key Recovery button that you can use. You need not to worry because I have step by step procedure below making it easy for you to do the process:
Discalaimer: Using the One Key Recovery will put back your machine to it's factory settings. Any important file/software you currently have will be wiped out. You might want to create back up copy first of all your files before continuing on the process.
Steps:
1. Turn off your compter.
2. Look for theOne Key Recovery button on your PC. It's near the power button.
3. Press the OKR button, wait until your computer turns on.
4. After Windows loading files you'll be routed on Lenovo One Key Rescue System.
5. Select One Key Recovery then, select restore from Intial back up.
Usually it will take 20-30 minutes for the whole process to be done. Once it's finish just reboot your computer. You'll now have the operating system reloaded to your pc. This should fix the issue.
Hope it helps.
Thank you for using Fixya.
Nov 06, 2010 | Lenovo IdeaPad Y430-3231U Notebook
My dell comes on but it doesn't go to windows it goes to an error screen what do I do?
What is the error? Is it a blue screen or some other type of issue? Did you recently change some hardware driver or OS setting?
What OS do you have installed - this is very important if you downloaded Microsoft updates in the past few days on a computer with XP. There was an issue with a patch and it has to be rolled back. The symptom of this issue is the blue screen with the message "Page_Fault_In_NonPaged_Area" The solution is detailed at: http://www.krebsonsecurity.com/2010/02/new-patches-cause-bsod-for-some-windows-xp-users/ . Microsoft will offer free phone support at 1-866-PCSAFETY and has an alternate fix here: http://support.microsoft.com/kb/979682
Other errors can often be dealt with by rolling back with system restore (carefully - you can lose other drivers).
I hope this helps.
Feb 13, 2010 | Dell Computers & Internet
Gateway PC screen blank, geek squad diagnosis motherboard issue
You could replace the motor board for less than $100 but I think the geek squad says the motor board is bad on every computer that doesn't start right up for them so I would have someone else look at it first. Or just get a new computer at walmart for like $300
Jul 23, 2009 | Computers & Internet
Not able to make partition in LENOVO Y430 Idea Pad laptop
  1. Take backup of all your data like picture,document, videos, etc...
  2. Put OS Cd in and As soon as you turn on tap F12 then select CD ROM on the list
  3. Then it will give a message " Press any Key"
  4. As soon as u see the message press Enter
  5. It Setup Vista OS then it takes to partition Screen.
  6. Delete all the partiton and Create a new partion C,D,E as your wish
  7. It will install Vista in C Drive
  8. For XP  click on the link for clean installation http://gur.in/clean.htm
  9. While selecting the drive, Select D as your partion. this will install xp.
  10. so you have DUAL Boot OS.
Hope this helps,
Thanks,
Prem
Feb 18, 2009 | Lenovo 3000 Y410 Notebook
Quick launch button for Dolby for Y430 36Q not working forxp
if the OS is changed to Xp then you will have to download the drivers for the hot keys from consumer support.lenovo.com and then you will be able to use all the quick launch facilities provided.Simply visit the site and choose your options as notebook and y 430 and you will be directed on that page.Remember tyo install patch for Xp before installing any driver as this is mainly for the sound but helps in connecting the PCI bridge to pci express as well.
Jan 26, 2009 | Lenovo 3000 Y410 Laptop
Blue Screen of Death
Just use ORIGINAL OS CD and repair OS everything will work fine!
Dec 27, 2007 | Computers & Internet
Lenovo IdeaPad Y430-3231U Notebook Logo
304 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
