Question about Kitchen Ranges
Replacing spark module and need color schematic for ignitor wires
I am replacing a spark module on an Amana gas range agr5715qds. Have the power supply done OK. I need a color schematic for connecting the ignitor wires properly. When disconnecting the power supply 3 of the ignitor wires disconnected from faulty spark module and I want to make sure I get them where they belong. Upper left ignitor wire remained intact so that is in proper receptacle. It is a orange/black tracer wire. Any ideas on other three? One is orange/black tracer and other 2 are 2 shades of orange.
thanks, David Thomas
5 Suggested Answers
SOURCE: Roper Gas Range
F1 Error
My Roper gas range is sounding an alarm call with number F1 flashing. Can anyone reveal what the code means before I call service? Thanks!!
Posted on Jul 28, 2009
jsrock516
  • 5911 Answers
SOURCE: Same issue - ordered ignitor for range. Doesn't fit...
Most of these igniters come with instructions that explain how to properly install them. If the connector plugs do not match, you should have been instructed to clip the plugs off and splice the wires together using the CERAMIC wire lugs that should have been included with the replacement kit. DO NOT use standard wire lugs. The heat of the oven will cause them to melt. Just make sure the oven is UNPLUGGED before attempting to install.
If you have any questions, please let me know. I hope this helps you.
Posted on Aug 20, 2009
Testimonial: "Thank you!"
  • 10865 Answers
SOURCE: I have an old Olsen
Hi Phil. Generally black wires are live, hot wires while white wires are neutral.
You may be correct that that tarnished black 110 was never connected.
That said, you will have to test each wire and see what's hot and what's not. Your goal it to get it working again, not to necessarily connect up every wire. J.
Posted on Sep 28, 2010
oldTech2332
  • 2341 Answers
SOURCE: I have a Viking vgic365-4G gas range. I recently
their is one of two things causing that,
1) the switch that supplies power to the spark module when the burner is turned on is bad...its located on the shaft of the burner valve thier is one switch for each knob so counting the oven and the burners their is 5 (the oven is different from the surface burners) to check those switches what needs to be done is remove the knobs then the face panel so ya can get to the knobs.
No is where is gets a bit complcated if ya dont follow all procedures....the knob must turned on to check so gas will be flowing and ya must light the gas using a match or raw gas will eneter the kitchen...or if possible temporarly turn off gas supply to the unit.also POWER MUST BE DISCONNECTED and then with power off and the burner lit manually once turned on ya would need to check each switch to have continuity,if any of the switches does not have continuity when measured with a ohm meter that switch will be bad
2) the igniter is cracked so power is coming from spark module yet since its cracked power is jumping out before it gets the where it lights the burners.
GENE
Posted on Oct 02, 2011
My maytag mgr5729adw gas range oven omits a strong gas smell when attempting to preheat. Sometimes it heats sometimes it doesn't but use to get a small boom when igniting. Ignitor still glows oran
see the next steps and proceed with common sense: God bless you
Main Control / Oven Switch
The main control or oven switch may have failed. You will need to identify the wires from the switch/control that lead to the igniter that is clicking. These wires may pass through the spark module and change colors. Refer to the wiring diagram or tech sheet. If you have power leaving the switch/ control when in the off position replace the switch /control. Manual switches can be tested with an ohmeter.
Spark Module / Igniter Module
If your oven igniter keeps clicking the igniter module or spark module is the likely problem. First be sure the igniter is clean and the surrounding contact points are clean. Make sure power is off when cleaning. If the oven keeps clicking after it's cleaned and the oven switch / control checks good replace the spark module.
Jul 26, 2012 | Kitchen Ranges
Hi there. there is no spark to ignite the gas in oven.
You will need to replace the spark module if you don't hear any clicking, or there is no spark present when trying to ignite the gas.
To test the Spark Module:
When properly operating, the spark module repeatedly produces a spark at the ignitor accompanied by a sharp snapping sound.
  1. Turn off gas and power supply to unit.
  2. Check wiring diagram to verify all terminals and wire connections are correct and tight with no cuts in the wiring.
  3. Prepare to measure voltage on spark module from terminal L to N.
  4. Turn power supply back on.
  5. Turn top burner to LITE position.
  6. If no voltage is present on the meter, this will indicate the electrical circuit is interrupted before the spark module
  7. If voltage is present, then check ignitor.
  8. If ignitors are ok; then replace spark module.
To access the Spark Module:
  1. Turn off electrical power and gas to the range.
  2. Disconnect gas and power from unit.
  3. Remove screws securing top surface burners.
  4. Remove surface burner and disconnect spark ignitor wire from surface burner.
  5. Raise and remove maintop from unit.
  6. Remove screws securing spark module bracket.
  7. Disconnect wire terminals from spark module.
  8. Replace and reassemble in reverse order.
May 18, 2011 | Amana Ovens
Oven wont turn on
The oven won't turn on unless it detects flame, typically starting a small flame (similar to a pilot light) with a spark first, then the valve allows the main burner to start.
If you aren't hearing the spark or don't see the ignition source come on, the oven will never turn on.
Feb 20, 2011 | Amana AGR5715QD Gas Kitchen Range
On my Amana gas range 2 ignighters work an 2 don't. Does that help to narrow down the problem?
Hi.
Either the single ignitors are faulty, or the ignitor sparker module must be replaced.
The sparkers are tested energizing them.
The ignitor hub module is located under the cooktop panel.
Check also the wiring harness to spark module.
Here all parts and diagrams for your range.
Regards.
Mar 02, 2010 | Amana ARGS7650SS Gas Kitchen Range
Amana AGDS902SS Gas Range Oven. Replaced ignitor.
Hi not that i can think of try google the range see if they have problem with this range
Feb 08, 2010 | Amana AGDS902SS Gas Kitchen Range
Kenmore gas range, light in oven won't shut off
the switch on the catch in the door is sticking . make sure there is no obstruction in the catch or the the wires on the switch are not shorting
Jan 28, 2010 | Amana AGR5715QDS Gas Kitchen Range
Range top ignitor stopped working. electronic panel and oven work normally. Any idea what the problem is?
Hi, your spark module,for ignitor could be damage, sometimes they burnt out, or could be broken wires, or corrosion at electrical connection, (terminal) , normally it's spark module, that's faulty or burnt out. let mechanic check. or remove range plug from receptacle, and lift top of range, check all electrical wiring, check all connection for rust (corrosion) clean and retry range, if it didn't work, call mechanic to check spark module. good luck.
Aug 12, 2009 | Amana ACS3350AS Gas Kitchen Range
Stove spark lighter won't shut off
The spark ignitor needs to be replaced. You can get it at your local appliance repair store or online at repairclinic,com. That is the way it tells you that it is bad by constantly clicking
May 22, 2009 | Amana AGR5715QDS Gas Kitchen Range
Blue flames on top of stove now more yellow than red
Have it checked out by a QUALIFIED gas person!! Don't screw around with gas unless you want to wake up dead due to carbon monoxide poisoning or an explosion!!!! Gas is NOT a forgiving task-master.
Apr 02, 2017 | Amana AGR5715QDS Gas Kitchen Range
Oven won't light or self cleaning but broil works
sounds like the spark module to me. you need to find the model # for this one. if you have the electrical schematic, you can ohm out the spark module.
the model & serial #'s should be under the door frame, when you pull out the bottom drawer.
Sep 13, 2008 | Whirlpool Kitchen Ranges
Kitchen Ranges Logo
194 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
