Question about HTC TyTN II Smartphone
Main battery low allthough battery is charged
  • 805 Answers
Change battery
Posted on Jul 18, 2009
2006 550i BMW What causes it to stop charging the battery
All modern vehicles have belts to drive the Alternator system which keeps the battery charged. The belt can get old and slip or even a new belt can get oil or anti-freeze on it and slip and then the battery gauge should show a low charging condition.There is also a main fuse on most cars after 1995 and on some earlier ones > Check your owners manual for fuse and main relays. The index should show you what page and then look and see if you have a main " PDC " or Power Distribution Center next to your battery. It should tell you in the manual which is the main fuse for the Alternator System. They can be anywhere from as low as 40 amp fuse to 60 amp and on certain vehicles higher. Pull the fuse if you have a PDC and look to see if it is blown. If not make sure your belt is adjusted correctly and look for any broken wires near the alternator or battery. that should help you start to find the problem...
Jun 05, 2013 | Cars & Trucks
My old 611 dosent hold the battery charge for long even though I have put in a new battery
An in car charger will not charge as well as the mains, when charging for the first time you should use the mains, and charge for at least 8 hours. If it didn't charge correctly, it will be the same low charge all the time, as the battery has a memory that makes it charge the same each time. Try charging from the mains, you might be lucky.
May 22, 2012 | Cell Phones
Acer aspire 5935g battery problem
Many users do not use their notebook/notebook batteries correctly. The battery in a laptop/notebook/netbook is a rechargeable battery, like the battery in a Cellphone, a Digital Camera an eReader or an MP3/MP4/MP5 Player. This type of battery needs to both charge and discharge, if it is to perform to its maximum capacity and have a full, long life.
You would never dream of using a Cellphone, Digital Camera, an eReader or an MP3/MP4/MP5 Player only with the devices permanently connected to the mains electricity, because they are all devices that are designed to be used while the user is moving around whether indoors or outdoors, powered by their rechargeable batteries. the batteries of such devices are only recharged when the charge in their cells is depleted and then only for as long as it takes to restore full charge to them.
As with the other devices mentioned, a laptop/notebook/netbook's battery is designed for mobile use and the user should charge it to 100% full and then stop charging it to then use the device on battery power alone, until the battery is low on power, when the recharging cycle can then be repeated.
A notebook/netbook has more flexibility than the other devices mentioned because, unlike the other devices, it can also be powered directly from the mains electricity, without the battery installed.
If your laptop/notebook/netbook is mainly used away from the home or office, it is fine to leave the battery permanently installed. If, however, it is mainly used indoors at home or at work and always or almost always on exactly the same desk or table, then it makes little sense to use it either on battery power alone or with the battery permanently installed.
Charge the battery up to full charge and then disconnect the battery from the device and keep it safely for when you next need to use the laptop/notebook/netbook on the move (if the battery is stored for long periods it may require additional recharging to both maintain the battery's condition and to keep it fully charged because low level power dissipation takes place in a disconnected battery). Then connect the device to the mains electricity without the battery and continue using it like that.
If the laptop/notebook/netbook is mainly used in a single permanent indoor location, then charging has to stop when the battery has reached 100% full charge and should only be resumed when the device gives a low battery charge warning.
It is also important not to let rechargeable batteries drain completely by ignoring the low battery charge warming and continuing to use the device until the battery runs out of charge and the device powers down suddenly. Sudden shutdowns like this are neither good for the battery nor the device and can shorten the lifespan of both.
Continuing to charge any rechargeable battery when it has already been fully charged damages and shortens the life of the battery. It can even damage the internal Power Management System of the device if done over a sustained period of time and/or for prolonged periods of time.
When your notebook only shows 75% as the maximum charging level, this is an indication that one or more (probably two) of the individual cells that make up the battery are fully depleted, damaged and probably no longer capable of storing a charge, for the reasons given above. You should stop charging this battery after it has reached 75%, otherwise more cells are likely to become damaged and so on until the entire battery is dead, unresponsive and useless.
Nov 20, 2011 | Acer Aspire One PC Notebook
Should i use my new acer 5760 on mains power when possible
It depends upon how much time you run your laptop on battery power, you can keep an eye on the battery charge level when you connect it to mains power. You do not need to keep it on mains power all the time, only when the battery level drops to a low level and needs charging.
The laptop will warn you when it is low on battery power.
Aug 29, 2011 | Acer Travel Mate 7720G-932G50MN Notebook
MY MC1000 SCANNER COMES UP WITH BACKUP BATTERY LOW HOW DO I FIX
when the unit is totally drain (main battery and back-up batter is totally drain), you need to charge the device at least 20hrs to fully charge the main and back-up battery check manual of mc1000 re battery charging @ page 21-22
Sep 16, 2010 | Symbol MC1000 Barcode Scanner
Battery won't charge.
Check your altinator wires are clean and tight.I have had some cars with that problem and its been the altinator regulator is the fault. Allthough the charge light goes out its still faulty.
Nov 18, 2009 | Mitsubishi Pickup Cars & Trucks
Main battery gets low allthough its fully charged can you solve me out by this problem
You have a deffective battery that doesnt hold the charge.
You should contact your vendor to get a new battery.
Jul 18, 2009 | Lands Phones
HOW TO CHANGE OR CHARGE THE BACKUP BATTERY?
y hp6365 keeps telling me that i my backup battery is low..i keep charging my phone but the only the main battery is charging..how do i charge or change the backup battery?
Feb 17, 2009 | HP iPAQ h6315/h6365 Pocket PC
I.Mate -JAQ charging problem
my i mate jaq charging jak iss broken i need charging jak jumoers
Aug 27, 2008 | i-mate JAQ Pocket PC
HTC TyTN II Smartphone Logo
276 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
