Question about Samsung HLN467W 46" Rear Projection HDTV
Hln467w Help, No picture or sound. Will not shut off with power button. Someone sugessted switching Ic or Micon. Where do you get these pieces?
  • 934 Answers
You don't - you would have to replace the entire module unless you have an expensive smt station.
What you're describing is the logic main board and possibly the dmd board as well. Something we call a cascade failure. I'd strongly recommend you take it to a qualified shop and have them do the repair. I can assure you it won't be an easy task for the shop either...
Bill
Posted on Nov 19, 2007
My dvd dv2022k has no display on the front screen power is ok , mainboard micon ic is too hot when power on
Seems pretty obvious to me that micon IC might have failed! Anything that gets hot to touch and does not have an heatsink on it might well be faulty. Since if it is natural for it to become hot, they would have put a heatsink on it!
Jul 16, 2016 | Televison & Video
Relay switch keeps shutting off
Hello Jamie,
Do you mean the house power relay? or is there a relay on the TV? if its the TV, and it is hooked up to a multi power outlet, try connecting it directly to the wall and see if this happens.. hope i can be of help!
Jan 05, 2014 | Samsung HLN467W 46" Rear Projection HDTV
Have 21,6umc switch on after 3-6mins picture & sound go off with a click, just left with blank screen with
Power supply problem, intermittent voltage regulator ic after it heats up it shorts out internally and tv shuts off.
Nov 18, 2011 | Televison & Video
Tv shuts off after 10-20 minutes
its not the problem with ur electron gun tube or with any picture ic or sound ic. Every t.v. is microcontoller switched machine.
any damage to microcontroller ic that controls the switching will lead to this kind of problem.
0.01% chance of residue EHT voltage would have affected the microcontroller.
Jun 06, 2009 | Panasonic TH-42PC77U TV
TV power light comes on but no picture/no sound
chip on ic board repair shop might replace it and reprogram if the tv is worth the fix
Feb 05, 2009 | RCA Televison & Video
Problem
Dear Nazir Ahmad,
I think, Horizontal deflection circuit got problem in your TV. If you are skilled/ qualified technician, then open TV set because your safty is 1st priorty.
May 27, 2008 | Sony KP-61HS30 TV
No picture no sound
this is most often caused by a faulty lamp or faulty ballast. try resetting the tv by unplugging and leaving it unplugged for 5-10 minutes or so, plug it back in and check it.
you should be able to find the replacement parts via partstore.com
ballast is part number BP4700017A
lamp is part number
BP9600224A
compatible cheaper lamp part number
BP96-00224ARL
hope this helps,
trin
Nov 19, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Will not power on
this could be a number of probs. needs to be ck'd by a tv tech can usually be repaired for a few hundred bucks suggestions..audio ic,convergence ic,signal board or power module..note these parts are pricey so trouble shoot to correct part. John
Sep 05, 2007 | Philips Magnavox 9P6034C 60" Rear...
Hdtv-dlp has no sound or picture
This sounds like an o-so familar problem. It sounds like the Switching IC or the MICOM has failed
Nov 10, 2006 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HLN467W 46" Rear Projection HDTV Logo
89 people viewed this question
Jerry Greenberg
Jerry Greenberg
