An error will appear regarding the modular bay everytime you turn on the computer and it will not allow us to go into set up.
  • brownleopard
    brownleopard May 11, 2010
    What is the exact error?
Device in the system modular cannot be identified.
Well it may be the hdd, RAM or a system failure. Reading into this common issue it appears the most likely cause is the DVD ROM. Remove the ROM and plug it back in or replace it. That may be the problem.
Jan 27, 2014 | Dell Computers & Internet
Hi my dell d610 does not recognise any dvd rom i
insert a good quality dvd in the drive. If no response, go to my computer and select dvd drive and double click, it may open. GL
Aug 19, 2013 | Dell Latitude D610 Notebook
Boot with pandrive
ashishkhare2,
This computer does not allow booting from a pen drive. Below are the boot options for this system.
Boot <First, Second, Third> device: Diskette Drive, Internal HDD, CDROM Drive, Modular Bay HDD, OR NONE
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 18, 2013 | Dell Latitude CPI-A Notebook
I cannot get the light to turn off on my Hampton Bay fan. Everytime I turn the fan on the light also automatically turns on. The remote appears to be useless, everytime I hit the light/dimmer button...
Possible that the logic control within the fan unit is defective if is seems to switch on both. For a start you can try to clean the remote pads to confirm if the pads are accidentally contacting when pressed for one function. If dimmer works then the selection mode could be the culprit.
Jul 04, 2012 | Hampton Bay YG092-VPW 52'' Preston Vintage...
Dell Inspiron 1100 problem
For Dell Inspiron 1100 Support just dial 1-800-204-4427 Dell Inspiron laptop support number to fix you error by expert technician. For more Click here : http://www.delltechnicalsupportphonenumbers.com/dell-inspiron-laptop-support
Jul 08, 2017 | Dell Inspiron 1100 System Board (...
At boot up , my vostro sends and error message "System in the modular bay not recognized" , and the Dvd/cd doesnt seem to work. It doesnt appear at MyPc and neither does it read any disc.
It may be due to the loose contact of the cables connected to the drive, if the tray ejects that means it receives power, tightining the cables should resolve the issue
Jul 28, 2010 | Dell Vostro 1400 / Inspiron 1420 - 24X...
When I turn on the laptop ...it says the dvice in the system modular bay can not be identified
Did you ever solve the non-recognition problem?
My C840 fails to recognize the/an extra HD in the modular bay, after I "overfilled(??)" it.
What to do to regain access to information stored on HD that the computer no longer recognizes? (Other components, including other HD's continue to work ok in the modular bay).
kcdd30a@aol.com
Nov 07, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Either issue with system modular bay or system file removed
remove any cd or floppy disks from the pc...reboot ..if the black screen reaper with the same message about the missing file ..you have to insert the windows instalation cd ...and repair..the missing file
Jan 28, 2009 | Dell Inspiron 2200 Notebook
This screen comes up when it is turned on: "The device in the system modular bay cannot be identified, etc.
I had the same problem.  I took out the optical drive, and powered it on, and it worked.  I may have to purchase a new optical drive?
May 22, 2008 | Dell Inspiron B120 Notebook
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
