Http://mxtoolbox.com/blacklists.aspx
https://www.ultratools.com/tools/spamDBLookup
it may be the other end ie the senders email server ip address. If a mail server has been sending out spam emails it can get blacklisted if the receiving email server is using the blacklists you will get a message saying the email has been blacklisted. I had this issue with my works email server it could not send me emails as the work email server was on a blacklist and my ISP POP server was rejecting the emails due to it being on a spam blacklist. My work had to contact the blacklist and get it taken off the black list.
SOURCE: IP ADDRESS TO OPEN ROUTER
assuming that you are plugged into your router and it has dhcp enabled...
IN WINDOWS XP:
go to start menu --> run --> type "cmd.exe" in the text field (a black window should pop up) --> in the black window type "ipconfig" (it will display your current network settings) --> look for where is says "Default Gateway" as the number to the left of it is your routers internal ipaddress
SOURCE: How do I secure my DLink-524 wireless
In securint your wireless security try accessing the configuration page of the router. go the the window where you created your wireless netowrk connection.
On that Wireless window choose WEP for security.
By defaut WEP Encryption is 64bit.
Under Key1 erase what's on the box and type in the password for your wirelss network. It should be exactly 10 characters, You could use 0 to 9 or A to F then click on Apply >next.
Try Accessing your wireless networ.
SOURCE: I'm trying to setup a static IP address for my
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
SOURCE: Google won't let me open the IP address 192.168.100 what do I do?
Maybe this will help:http://kbserver.netgear.com/pdf/wireless_router_setupmanual.pdf
