The installation cd won't load. I have a windows and me computer is that whyWhat usb port should I run
I load the cd. Comes up too dark to really see. I don't know what flash player I need or whether my computer is not compatible. USB port? which one? MTP or MSC
  • leemon1972 Dec 16, 2007
    mp3 player ds-31024 can't load cd
    Guru:
  • 1,463 Answers
I suggest going to the mp3 makes web site and getting the drivers from there .
post back make of mp3 if cant find the driver to download.
riz.
Posted on Nov 19, 2007
Playing music loaded to USB Flash Drive on stereo
Check that your system is compatible with the file. You may have to convert files.
Sep 07, 2017 | Pioneer DEH X3500UI - radio / CD / MP3...
Windows vista
There were several models made in the Classic format.
Early units had either Firewire or USB ports.
If USB...you would need an External CD Drive that plugs into the port on the player. Drivers would have to obtained from Apple at their web site and copied to a CD. Then a CD with the drivers would be inserted into a USB CD Drive and loaded on tot eh Player. The other solution is to Download the Drivers onto a computer, insert a FLASH Drive into the USB port on the computer, copy the drivers to the Flash Drive, and move the Flash drive over to the IPod's USB port. Copy the drivers or install from the Flash Drive.
Apr 03, 2014 | Apple iPod classic MP3 Player
Sony 5 cd changer disc exchange system With usb port
All this digital stuff can be more confusing for the user than standard tape systems. You may need to put files on the flash drive that are compatible with the CD changer for the files to be imported. Check the internet about this problem with the model unit you have and I bet you are not the only one having this problem. The flash drive may need to be having cda file son it or maybe something else.
Dec 15, 2012 | Sony CDP-CE375 5-Disc CD Changer
My camera will not connect to my computer through my usb cable
the cause why your camera doesn't recognized by the pc, first if the usb cable is not compatible or if it was defective tried to replaced it. then secondly if your camera not plug and play which need the installer cd of the camera.lastly if the usb port of the pc doesn't work tried with other usb port or you can plug with other device just to ensure if the usb port of the pc is working good luck.
Dec 09, 2012 | Samsung St65 14.2mp Digital Still Camera...
My Walkman.. is Loading forever and cannot open
1.Try resetting the Walkman by pressing the RESET button located on it. It looks like a small hole. You can use any pin or any sharp pointed object to reset it.
Then connect back the Walkman to check whether it works.
2. Use the supplied USB cable to connect the Walkman to the Computer.
3. Disconnect all other USB devices if you have connected to avoid conflict.
4.Connect the Walkman to the other USB ports on the Computer.
5.Check whether the USB Driver is installed in the Computer or if it is corrupted.
You can check whether the USB Driver is corrupted or not by following steps below(only for Windows Operating System).
Right-click on MyComputer icon and select "Manage".
Then, select Device Manager at the left plane.
Then check whether any "Unknown device" or "?" or "!" is listed under Universal Serial Bus Controllers at the bottom of the right pane.
If there is so, then right-click on it and select uninstall.
This will un-install the USB Driver.
Then, un-plugg the USB cable and plug-it in.
Now, the Walkman should be recognized as a removable device in My Computer.
If the issue persists, then connect the Walkman to a different Computer to check whether the issue is with the Computer or the Walkman.
If the issue persists even with different Computer,
If the issue persists you may try using a different compatible USB cable.
Jul 22, 2010 | Sony NWZB133F MP3 Player
USB port is not working
first check whether ur os is windows 98 or xp if it is 98 then for any device u need usb driver. if it is xp ten its ok. check the device manager whether usb driver is loaded in ur system. right click on my computer icon not the shortcut icon. then select mange then select the device manager from the option available on left hand side of the window. then check the usb section whether any driover is loaded into ur system. if not then install from ur motherboard cd. if that also does not work them u need a replace of the usb port.
tell me u have a error message window cannot recognise the usb. if this appears then it need a replacement of the port. thank u
Feb 25, 2010 | ASUS P5PE-VM Motherboard
How can i install in on my computer
The computer must have a usb port before you can install the MW-3805 (128 MB) MP3 Player. Also the OS musthave the usb Driver for the USB Port. Insert the MP3 Player into the USB port and the computer is surposed to automaticaly identify the Player after few seconds. If the OS has a compatible driver the driver is loaded and your MP3 is ready for us. If the OS does not have a compatible driver, load the driver CD that came with the device when prompted. when the diver is loaded the mp3 will be ready for use.
Dec 27, 2009 | GPX MW-3805 MP3 Player
Really i don't know what the problem is. the creative doesn't charge and when it charges don't do anything
the player seems to need longer charging:
1. while player switched OFF: let it load on ac-adapter or USB-connection**** for about 1 hour, until the screen lights up.
2. still while player switched OFF: let it load another 2 to 3 hours
to get it fully charged.
**** notice: when using USB for charging:
1. Install the application software (from CD or Creative-download)
2. Preferred is a USB-connection at the backside of the computer
3. When more USB-connections are used, have the others disconnected: trying not to overload the USB-port power-consumption.
Support for Zen Vision M on the site of Creative:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=14331&prodName=ZEN+Vision%3aM
Aug 12, 2009 | Creative Labs ZEN Vision:M Digital Media...
Flash loading
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 30, 2008 | iLO (2 GB) MP3 Player
Ilo 2gb mp3 flash player cd problems
Nov 26, 2007 | iLO (2 GB) MP3 Player
108 people viewed this question
 Grubhead
Grubhead
