When turned on only works on 1st speed
SOURCE: Faulty Homedics SBM 300H Therapist Select Shiatsu.
My mom had the same problem so i unzipped it from the back, and once i started to take out the padding i saw that there was a wire unplugged so i plugged it back in and it worked!
SOURCE: my homedics back massager with heat, stop working
the back massager with heat stopped working, bought a new power cord, still does not work, must be something in the back massager, but what to do ? ken
SOURCE: remote doesnot work
If you have not already, register your product with the company. And contact them regarding the malfunction. they should replace the part or the product if you send it in.
SOURCE: how to replace power cord om homedics massager
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
SOURCE: I've plug the 110-v Homedics massager into
I managed to get it fixed this weekend.
What I basically did was , I
opened the cushion that was basically zipped up , then there was a plastic
casing which was easily removable by unscrewing the screws.
then if you
follow the power chord , you will find that it is attached to a pcb . This is
the adapter. This adapter is then connected to another pcb through an easily
removable power clip. What I did was I took this to an electrician . The whole
unit looks like a laptop power adapter , but without tHe outer black casing. If
you stay in bangalore you can take it to sp road, there's this shop that works
on speakers. The electricitritian told me that a capacitor and something else ,
I don't remember , had blown up. He replaced it and it started working with a
120 / 220 volt 50 watt voltage converter. I have MCS-700H, check what is your
power rating, its written the label which is in the seat of ur massager. If ur
not sure buy one with 100 watts .
Hope this helps!
Btw it cost me
300 to repair and 200 for the voltage transformer.
