Question about Maytag MMV4205 Microwave Oven
Over the Range Light Bulb
My Maytag Microwave has the Over the Range Light and I can't find a replacement bulb that will work with the dimmer (high, low)on the microwave
    President:
  • Maytag Master
  • 1,922 Answers
"Appliance Parts Pro's" web-site bet they will have it or can get you the exact thing you need
Posted on Jul 27, 2009
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
How to change the hood light
By hood light I assume that the light you want to replace shines from the bottom of the unit, not the light inside the microwave. If so check out he Disassembly video on this site: Maytag Microwave Light Bulb Not Working
Jan 02, 2015 | Maytag MMV5207BAW Microwave Oven
I need to replace the cooktop light bulb-mmv5208ww
You should try to at least find the same wattage. The light bulbs are not dangerous safety hazards if they are made to fit microwaves.
Nov 07, 2013 | Maytag Appliances Over-the-Range Microwave...
The night light switch on my maytag over the range microwave will not work
I am assuming you changed the bulb. Anything that sits over a stove will become mucked up with grease and cooking oils etc. That can prevent the bulb from seating in the socket, the switch from making contact, etc. Unplug the unit, remove the bulb and get int here to clean the grease out. That should fix it.
Nov 03, 2013 | Microwave Ovens
The bulb light inside the microwave went dead with the microwave working perfectly...how do I replace the bulb?
Replacing the cavity light requires taking off the outer wrapper to access the bulb. Nothing easy or magical just an exercise in patience.
Eric
Jul 05, 2010 | Maytag MMV4205 Microwave Oven
Light won't go on; Model MMV1153WB-O
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
■ Cavity light: The cavity light bulb is located behind the vent
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. Hope this covers it.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
May 06, 2010 | Maytag Over-the-Range Microwave
Maytag MMV5165AAS work surface light won't work. I bought a new light and replaced the old one but it still will not turn on. THe microwave display goes thought the cycle of High, Low, Off but nothing...
If the lamp socket has power (and it's the right voltage) and the replacement lamp is the correct one and tests good, then the trouble is in the socket. It may have been damaged when the original lamp went "poof." Check for damaged contacts (burnt or broken off). Also, make sure you're seating the lamp correctly in the socket. If the bulb is a push-and-turn ("bayonet") type, you may be facing it the wrong way and it's not going all the way in.
Nov 11, 2008 | Maytag MMV5165 Microwave Oven
Maytag Over The Range Microwave #MMV4184AAW//No Power
no Mdicker, there is no safety thing that it would not run if there is a bulb missing or not installed.
i'm guessing that there is a fuse inside that went out when the bulb broke.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Maytag Appliances Over-the-Range Microwave...
Light socket is dead on my Maytag
Yes, this is caused by not disconnecting the microwave from the power line when removing or installing a bulb or by the filaments shorting when the bulb blows. This is a problem with the control panel assembly, which we repair nationwide for $39.95. If you or a friend decide to send it to us, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 01, 2007 | Maytag MMV4205 Microwave Oven
Maytag MMV4205 Microwave Oven Logo
473 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
