Honda 12 odyssey cd player says bad disc eject
The cd player makes a buzzing noise when the car door is open (even before we turn the ignition on). After we start the car in a few minutes the buzzing noise stops. The green light on the CD player stays on when the buzzing noise is occurring. An error is displayed that says bad disc and eject. I have tried all methods and am not sure there is actually a disc inside. I have tried disconnecting the battery, the fuse. It still is buzzing.
  • Conrad Bates
    Conrad Bates Jul 01, 2018
    Hello! Did you ever find a fix for this? My 2012 Odyssey just started doing this. Thanks!
  • Conrad Bates
    Top Expert:
  • Audio Player... Master
  • 53,678 Answers
The symptoms suggest a CD is jammed inside. You will have to remove the player and open it up to find the problem and correct it.
Posted on Aug 15, 2016
SOURCE:
Honda Odyssey CD player
It sounds as if the player laser is dirty. Vacuum all around the insert slot and then take some canned air and blast some air in there being careful not to inject any liquid propellant while doing so.
Try that first, and test. If that doesn't help, get a cleaning CD and follow the manufacturer's directions.
If that still doesn't help, you've got yourself a failed disc reader and you'll need to replace it. Good luck!
Dec 01, 2017 | Honda Cars & Trucks
2001 honda odyssey...my radio works fine, but the CD player wont accept any discs!
If its a 6 disk cd system the cd tray is wedge causing the cd option to not work. Most of the time one of the cd slipped out of its position causing it to wedge
May 19, 2015 | 2001 Honda Odyssey
I have a cd stuck and it constantly sounds like it it trying to change to another cd, can't even get another cd partially in door!
remove the the unit and see if there is a reset button at the rear , might be but depends on make , may just have to replace the unit
Jul 19, 2014 | 2006 Ford Mustang
Buzzing and Ignition Issues
Sounds like a weak battery, or bad connections at the battery/etc. Could also be a security system issue. Without hearing the noise it is difficult to help you pinpoint it. Maybe compile some more info with specifics like when? how often? cold or hot engine? cold or hot outside? Does the engine crank slow/start normal when it does start? Do you have any non-Honda alarms/gps/tracking systems installed? If so, that's where to start. 99.9% of the time these types of probs show up with non-factory security systems installed, it's caused by the aftermarket product, or sloppy installation by vendor.
Mar 05, 2014 | 1997 Honda CR-V
Whining noise before start chevy impala
low battery is probably a safe bet. Cars use electricity even when they are not running.
Feb 14, 2014 | Chevrolet Impala Cars & Trucks
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
Trouble starting, making weird noise
possible door switch bad or loose wire
Jul 30, 2017 | 2001 Chevrolet Impala
CD stuck in my Honda Odyssey CD changer
Turn van off. Open & close drivers door, wait for everything to power down. Turn van back on and push button to close CD/Nav opening. It will close. Having an issue with CD player also.
Mar 19, 2012 | 2008 Honda Odyssey EX-L
How do you remove a CD that is stuck in the factory installed cd player 2005 odyssey?
Hi.
All you can do without disassembling is pressing repeatedly the eject button while you turn on the unit at the same time. You can try first turning ignition off and on, then disconnecting the battery.
If that does not work, then the CD player must be pulled out and disassembled to access and remove the disk.
Try first turning on the unit and pressing repeatedly the eject. If there is no mechanical problem with the CD player that will work. If that does not work, then the player usually needs repair.
Jun 18, 2011 | 2005 Honda Odyssey
I have a 6 y.o. whirlpool fridge wbm 46 model that's started to make a loud buzzing/whirring noise every 15 minutes or so ( only lasts a few seconds each time). It's started doing that noise in the last...
Hi
The sound from your refrigerator can be caused due to various reasons,please check this link bellow to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnoisy
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Whirlpool Refrigerators
397 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
