Question about Electrical Supplies
New generator,first time run,correct oil and fuel added,however,after a few minutes running cuts out
  • 98 Answers
Replace carburator..
if u have any further questions email me at sal_kh_sab@yahoo.com
Posted on Oct 15, 2009
Kipor generator 6500 starting and stoping after few minutes running what could be the problem Diesel model
Im taking it as the engine is cutting out?
Is this a diesel model?
Try, low oil cut off, fuel tank not vented correcly, fuel blockage.
Feb 25, 2018 | Kipor Electrical Supplies
Onan marquis 5000 model # 5bgmfa26105f runs for a few minutes and shuts off. let it cool off and it will start again. whats the problem?
There are many possible reasons from stator output voltage to sensing, to fuel to control boards. A good place to start (as the unit does run) would be with the fuel system, if it has sat a long time it won't help. Also the fuel filter. try conencting to an external fuel tank versus the vehicles, as sometimes pick up tubes in main tanks can be an issue. Also check the correct oil level and viscosity / and oil pressure switch. Failing that I recommend a service center, as there really are so many causes, I cannot list all on here.
Aug 01, 2013 | Watts Onan Portable Generator - 5000 ,...
Engine starts and runs fine for about a minute
try to clean out the carb first with auto parts carb cleaner, then you may need to buy a totally new carb for the unit, as this company will NOT sell parts for these carbs due to the carb setting is sealed & has to stay at a set level for voltage output and setting
Nov 05, 2009 | Coleman Powermate Premium Plus 6250W...
Generator will shut off after running for 5 - 8 minutes... sputters a couple of times then cuts off. It has proper amount of oil & plenty of good fuel. I can let it cool off a few minutes and it starts...
I would change the fuel and air filters, very inexpensive fix. A rich or lean situation on them can make it act the same way. Or if you want try one or the other first.
Oct 04, 2009 | Kitchen Appliances - Others
My honda gx160 generator keeps cutting out after 2 mins
Sounds like fuel flow is restricted.
Is the vent cap on the gas tank clear?
Pull the fuel hose off at the carb and let run into a container from the tank......is fuel flow good while filling a cup or two worth of fuel?
If not check filter at fuel switch or at hose connection at tank for restriction.
It takes about 2 minutes to use up fuel in the carb with engine running.
Sure sounds like a fuel problem.
Sep 06, 2009 | Master Heaters MASTER HONDA POWERED...
Coleman Powermate 6250 stops after 5-8 minutes of running
the carby needs to be cleaned out properly the jets blown out with air.when you intendto stop useing for any length of time swich the fuel off and let itstop by running out of gas or drain the carby before storage ,as fuel evaporates and the additives dont they build upafter a while and start to block the jets make sure motor is level,oil cutoutcan be fooled if not level ,disconectwire if worried about that bing the problem
Jul 28, 2009 | Coleman Powermate Premium Plus 6250W...
My chainsaw wont run at full speed
Dump the gas and start over, pour some chem-tool in the tank slosh it around for a wile and dump it out, then refill your saw with NEW PREMIUM GAS and NEW OIL mixed at the correct ratio, it will take a few minutes to get the old fuel out of the line but then it will run like new, Gas and oil goes bad faster these days as oil company's no longer put in as much if any stableizer's
Feb 20, 2009 | Husqvarna Garden
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
