Question about Electrolux Harmony Canister Vacuum - EL6985 Vacuum
Lid won't close. I started to put in a new bag but accidentally took out the plastic insert section the bag should attach to--so when I closed the lid over that, I must have pushed a little too hard. Now it won't com[pletely close! The plastic clasp is intact. Is there anything I can do before having to haul or send it for repair?
  • 21 Answers
Your supposed to take out the plastic part that holds the bag but the way this unit is designed the lid will not close unless everything is inthere correctly so just make sure evverything in inserted correctly and keep trying! DO you still have your bag holder?
Posted on Jul 19, 2009
  • Rodboy Feb 27, 2011
    Yes it is true the lid will not close without the bag and holder in place. Check the tip that is the latch to see if it broken if not, try reposition it, but if it is broken electorlux has a web site with parts, Most of the parts are low cost except the cord winder which is 142 dollars.
Attach new torsion spring and bracket for miele s5211 vacum bag
Hi There, I put up a new video just recently showing how to fit the bag holder on a miele vacuum. Have a look it should be helpful.
Feb 08, 2013 | Miele S5260 Bagged Canister Vacuum
My Rival food saver does not vacuum air out
We discovered we were not moving the bags in far enough to be grabbed properly. After pushing in the bag before closing the unit we found it started sealing properly. This was on an older system, so be sure the bags you're sealling are between the black rubber rectanglar sections before closing the door.
If this is for a canister, be sure the rubber around the lid is seated properly. The rubber can be removed, cleaned and wiped dry. Clean out the lid and dry it too. Reseat the rubber seal and try again... Hope this helps.
Apr 19, 2010 | Vacuums
How do you change the bag in a kenmore progressive true hepa canister vacuum?
There is a latch just under where the hose enters the main canister section, just behind the handle. Pull back on the latch to open the bag compartment. The bag will pull out of it's plastic holder, then slide the new bag all the way in and close the lid.
Apr 14, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Hello, we have a Miele cat and dog turbo 5000 vacuum cleaner which we bought in December. It has just started blowing air out of the grid on the top of the cleaner instead of sucking from the tube. The...
The lid not closing properly is almost certainly the cause of your problem. Without that lid sealed tight to the body you will get no suction through the hose. So, the question is: why isn't the lid clipping down properly? Did you just change the bag? You need to check that the bag is properly located and that there's nothing getting caught where it shouldn't be. Get the lid closing properly and your problem should be solved. Good luck!
Dec 29, 2009 | Vacuums
Dust compartment lid won't close
Hi Depending on the filter you have, you need to check that the filter grid has been securely locked in at the back. Check that it "snaps" down and locks into place. Then check the position of the bag. If the bag is sitting on the rising bag lock slider then the hinged slider needs to be pushed down into the bin. Usually the lid will close and lock down if you remove the hose. Try this to see if it works. Then check to see that the bag is opened out where the hose usually goes - if the mouth of the bag (and this also includes the new HyClean range with the seals already built in) looks out of angle then it has slipped upwards. This usually happens if the bag hasn't been folded out properly and can take milliseconds to put right.
Then put the hose back in and lock into place.
Has this solution been Fixya? Please rate accordingly or msg again if you need more help.
Mar 28, 2009 | Miele S4580 Luna Bagged Canister Vacuum
Hoover telios Bag holder, fitting
HI The bag holder slips into place by opening the lid and aligning the bottom sections into the slider L shape part just at the mouth of the actual dust bin. Slide the part so that it sits at an angle before the bag slips into it. Once that's done make sure the bag is pushed down otherwise the lid will not close.
Feb 25, 2009 | Vacuums
Lid won't close
You might have the vacuum bag in incorrectly. Pull your vacuum bag all the way out, and check the cardboard for arrows (as some bags are cut to go in one way, and one way only). If your vacuum has a cartridge that the vacuum bag goes into, make sure that this is seated completely, securely, and correctly. After you have checked all of this, seat your lid meaning make sure it is going to sit correctly on the housing, then as you are closing the lid, check the latch as it begins to close - making sure that the male and female portions are going to match up. You may have to give it a little pressure, but should not have to put enough pressure to break anything. Good luck.
Jan 21, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Sebo felix upright
Hey Debs
Ive got a Sebo Felix. Unfold the bag (if its folded) and drop it into the top of the bin. Once you've aligned the plastic parts the two nibs which are pointing outwards towards the handle, make sure the plastic collar is sitting on the rest of the surround.
Now the most important aspect is the plastic flap - not the dust cap - but if standing behind the Felix, there is a green flap on the left hand side of the bag which must be pushed down over the spring (looks like a large staple). Once that is folded over and locked in, the lid should close. If the lid still doesn't close check that the top hose fitting has been securely locked and is dust free. Dont forget to rate, ty.
Jul 25, 2008 | Sebo Vacuums
Electrolux epic keeps shutting down - ? symbol is on
The "?" sign is usually indicating that there is no bag in the machine. On the Canadian models, there is a switch that the cardboard of the bag pushes on when the lid is closed. If this switch is not depressed, then the machine will not run. Again, on the Canadian models, there is a clear plastic "pin" extending out the bottom right corner of the bag compartment and is pressed in when the bag is installed and the lid closed. You should be able to press this in and start the machine with the main switch, just to test it.
Jan 06, 2008 | Vacuums
Kenmore Bagless Issue
after cleaning the filter,replace the bag.But this time before you close the lid,make sure you remove the hose.after the lid is closed then put the hose back on.
leaving the hose connected to the lid after closing will create a gap between the bag holder and the bag.so just remove the hose first before changing the bag
Jun 16, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Electrolux Harmony Canister Vacuum - EL6985 Vacuum Logo
339 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
