Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
The spinner stopped spinning
The washer seemed to be working fine then when it went into the spin cycle, nothing...?
  • johnea Nov 20, 2007
    I held down the switch; the spinner still doesn't spin. Sounds like the issue is under the drum.
  • 447 Answers
Lid switch
Posted on Nov 19, 2007
  • joey  shearer
    joey shearer Nov 23, 2007
    Yes sometimes its not the lid switch. But its the first thing to check. Does the machine agaitate???
My ge front load washer fills then stops during cycle and does nothing else. It spins in the beginning then will not drain at the end
It sounds like the drain pump itself is damaged--the important clue was the humming noise. It could be bound up mechanically or the impeller could be damaged and just vibrating instead of spinning. The part number for the drain pump is WH23X10026. The fact that the pump was humming tells me that the 120v supply is being turned on by the main control board and that the wiring is good all the way to the pump. When I service customers, I try to save the pump if possible in clog cases. Most of the time, they aren't damaged from a simple clog. But, occasionally, the impeller cracks, or the nylon blade gets loose on the shaft, or the motor windings have defects from heat, etc.
Jul 23, 2015 | GE Energy Star WCVH6260F Front Load Washer
Kenmore agitates doenst spin
You will have to look at the inside of the washer when in spin cycle to see what is going on. Is the spinner motor not engaging the drum? Is the spinner working at all? It sounds like the spinner isn't being moved against the drum before the spin cycle starts. Most washers use a seperate spinner motor, which is lifted off the drum by a relay and / or solenoid and if one or more of those is malfunctioning, it will cause your described problem.
Dec 22, 2007 | Kenmore Elite HE4 Electric Dryer
Washer stopped during spin cycle
Hello, try to checked the pump filter, and the pump is actually working. then I would suspect a draining problem.
If filter clean and pump works fine then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Jun 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
Drum seems off balance....
You likely have a corroded/broken spinner assembly on the back of the inner tub. If your washer is out of warranty it is usually cost-prohibitive to repair. We usually quote about $350-$400 parts and labor for it. If you can wiggle the inner basket relative to the outer, that confirms a broken spinner.
Apr 20, 2010 | Frigidaire GLTF1670A Front Load Washer
Maytag washer stops during spin cycle
it seems like aproblem w motor maybe need to acouple of new carbon brush to fit in motor
i think that because it seems to me from your words that the motor only works w no load
Jul 11, 2009 | Maytag Dependable Care LAT9706
Does Nothing During Spin Cycle than quits
You have a motor coupling gone.
Jan 25, 2009 | Washing Machines
My washer will not work in the spin and rinse cycle.
Whats happened is that the clutch/brake assembly is stuck.Without a qualified service tech. you can really get taken if the repairman doesn't know the trick to this.I can walk you through this step by step and you need only a 5/16 nut driver or socket.
Dec 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Old Washer won't spin or agitate
change the spinner switch
Apr 01, 2008 | Washing Machines
Washer does not wash or spin
the electronic module who drives the motor its the problem . you can order and replace find part at go by brand and model let me know if you need more help thanks
Jun 20, 2007 | GE WSXH208A Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
42 people viewed this question
Dan Webster
Dan Webster
Sal De
