SOURCE: Washer agitates for a time then sputters. Does not spin
In sounds to me like you have a motor issue. We have found that on these particuliar models, that the motor tries to run in both speeds at the same time. If you already replaced the control board, then you will have to get a new motor kit. This kit includes directions as well as a new wiring harness and start capacitor. You would have to remove the old motor and rewire the wiring harness (instructions included with the kit) and add the new start capacitor (instructions also included). Job is'nt really that hard to do. Front cover would be all you would need to remove to get to all the parts. Good luck and let me know how it turns out or if you need any additional help. Jim
SOURCE: Door Lock LED flashing
The solution from testy helped me but I decided to change it.
I cut the plastic latch away from the end of the interlock,just the little bar that holds the door closed.This means that the lock position doesn't affect the door.
I then used the little piece of plastic to act as 2 packing pieces to hold the lock half closed. This works fine.
Don't push the lock fully closed or it doesn't work
SOURCE: C514 STOPS mid cycle
I'm having the same problem. It's new and it did it with the first wash. Can anyone help.
jackie
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
SOURCE: the wash enhance button is flashing.
wash enhance and on/off button flashing on washing machine'
