Question about HP Officejet J5780 All-In-One InkJet Printer
Officejet J5780 Every time I turn printer on I get error reading to align cartridge. Tried several cart. and get same reading
One "reset the printer" solution says:
1. unplug power cord
2. wait 30 seconds
3. hold down "#" key AND "6" key, plug in power cord and turn on
this theoretically should clear it. i had a similar problem with an HP 6100 multifunction, and the "reset" steps with that were similar (different keys) and worked.
Posted on Aug 03, 2009
I have not use my printer for almost 5 month, I just purchase the HP touch screen. I download the driver and I was able to printer but the printer continue to make a loud like it try to realign. What can I do, the ink is low but I don't wanted to buy ink if it not going to work.
Posted on Aug 22, 2009
What cause lose of new ink on aligning cartridges.
Unfortunately, the printer does not actually measure the ink in the carts, but measures how many droplets called for. The carts may actually be full, but the printer now thinks they're empty. Most likely the black ink needs to be "charged" because you've cleaned out the pipe. I don't know what to do to charge it, and you'll likely need new carts.
Sep 11, 2014 | HP Officejet Pro 8500 All-in-one -...
Saying cartridge error when cartridge is inserted correctly
CLEAN JACK OF CART. & THE CARTRIDGE ITSELF & INSTALL YOUR CART. AGAIN
REMEMBER IF YOU USE REFILLED CARTRIDGE IT WILL SHOW ERROR ,SO ITS BETTER TON USE GENUINE HP CART.(ON INSTALLING GENUINE CART. IT WILL ASK FOR ALIGNMENT SO CLICK ALIGN WHEN PROMPTED.)
Feb 12, 2011 | HP Officejet 4355 All-In-One InkJet...
I have a hp printer officejet J5780 All imn one.
I have found this model has a bad buildup of black ink in the right carriage bay chamber. With the printer on, open the carriage access lid and pull the power cord before the cartridge carriage can move all the way to the right side. Then gently push back the cartridge holder on the right if it's in your view, so you can see if there is a collection of black ink. The tri-color cartridge has a preventive bracket that doesn't seem to build as much as the black one. Anyway, once you've cleared any dripped ink cones or globs, plug the printer back in, turn it on, and if you get the Carriage Jam error one more time, press OK, and it should work well if that was the block on the carriage movement. I hope this helps you to get printing again.
May 04, 2010 | HP Officejet J5780 All-In-One InkJet...
HP Officejet J5780 all in one Alignment problem cartridge will still not align after I've gone through the alignment routine. Cartridges are genuine HP and fairly new
Usually the yellow is the culprit. Dab the cartridge on a paper towel and see if all colors make a spot or line. if any color is missing it will not pass alignment, and you need a new cartridge.
Dec 30, 2009 | HP Officejet J5780 All-In-One InkJet...
Hello! Copies are very poor. New ink. Copies
Try to align the cartridges again...
Steps to align : press the setup button.. > go to tools > align cart and clean cart
Oct 19, 2009 | HP Officejet J5780 All-In-One InkJet...
I insert a new print cartridge and align it as asked. But the printer says it won't align. I have an HP officejet J5780 all in one. Thanks.
Several Steps to take.
If all else fails try a new or different cartridge before you get too carried away looking at the printer for the problem.
1. Turn off the printer and unplug it from the power source for approx. 30 seconds (some units take this long to bleed the power out of the unit).
2. Plug in the printer and step thru the start up procedure (turn it on what ever - not the set up program).
3. Retry the cartridge alignment procedure.
4. If alignment still fails verify that the cartridge electrical contacts are clean and the jet opening is not blocked.
5. Reinstall after cleaning and checking.
Aug 21, 2009 | HP Officejet J5780 All-In-One InkJet...
I have an hp officejet j5780 all in one and am struggling to get it setup for the 1st time. Installed cartridges & following the alignment procedures. 1st part where it prints from the bottom tray is fine...
Normal 0 Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | HP Officejet J5780 All-In-One InkJet...
Color Cartridge Error
if u r sure about the catrige then its a problem with the carriage unit ,in which the catridge seats,it has to be replaced.
thnx N
Feb 01, 2008 | HP Officejet J5780 All-In-One InkJet...
OfficeJet K60 All In One Problem:Aligning Cartridges
In the process of alignment there are two phases:
1. When the message comes to align the ink ..press ok and the page is printed out.
2. Once the page is printed then place the page on the scanner glass and tehn scan the same.
Follow these two steps in the same order and it will never give Align Ink Cart message again.
Oct 24, 2007 | HP OfficeJet k60 All-In-One InkJet Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
553 people viewed this question
Seeker5211
Seeker5211
