Baby Gear Logo
C
Carol Robison Posted on Aug 14, 2016
I need the harness and seat straps for the Kelty Deuce Coupe double stroller. I need to know how to get them. Thanks
5 Related Answers
katelynn0061
  • Posted on Jun 13, 2008
SOURCE: Car Seat Installation on Stroller
Call the company the number is on the back of the seat ...They will send you one.May cost a few dollars but not much.Also try ebay
Anonymous
  • 29 Answers
  • Posted on Mar 17, 2009
SOURCE: Peg Perego Pliko 3 5 point harness strap
Contact Peg Perego
800-671-1701
Anonymous
  • Posted on Apr 21, 2009
SOURCE: Straps ripped on my Instep double jogging stroller (11-KA200)
Instep does have replacement parts for some of their strollers. For $25 I was able to purchase a new seating pad.
Anonymous
  • 20 Answers
  • Posted on May 08, 2009
SOURCE: Need help reassembling the straps after washing the seat cover
First turn seat upside down. There should be a slot on each side under the seat, run strap through each slot and turn back over. Pull strap up evenly, put on clasp part on each side, then put chest clasps on, run your straps through back and secure to strap comes between legs.
Anonymous
  • Posted on Sep 09, 2009
SOURCE: harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
1helpful
My 2 year old can get out of bugaboo even though she is strapped in? Is there extra straps or a harness for bugaboo
The Bugaboo's like 99% of all strollers have a 5 point harness. Two shoulder straps Two Lap straps and a center strap with the main body of the buckles. 2 year olds become little Houdini's pulling the shoulder straps off in both strollers and car seats. There are small buckle units you can buy that lock the two shoulder straps at chest height these are excellent at keeping kids in their place. Ask any nursery supply shop they should have them.
2helpful
How do i take off straps to clean or wash them
Good Afternoon
The harness straps are attached to the sub seat (seat frame) of the Buzz and do not come off.
To clean them, remove the seat fabric to expose the entire length of the harness straps, and use a bowl of warm soapy water and a sponge.
1helpful
Hi, my friend is giving me a Bobs Revolution Duallie stroller (2007) however her husband cut off the harness straps. Is there anywhere I can go to purchase a replacement seat with the harness?
I have a similar problem. The crotch straps on mine dry-rotted and tore off. I spoken with BOB reps and they say there is no seatbelt replacement. I\'d have to buy a whole new seat. Fortunately I still had the buckles and I was able to just sew replacement straps in place. Good luck!
Kelty double strollere
Yeah you can give it a try - I did.
Quinny harness pads
Hi if you bought buggy in 2007 contact dorel with proof of purchase they will send you new extensions & an xl seat cover. They also can supply the harness pads but you can pick them up cheaper on ebay.
Where can I get a harness replacement for my stroller? Thanks i,m in the UK, my bugaboo frog aubergine has a broken harness from the seat frame, where can i get a replacement
Hi, I trust that you mean the waist straps? I would suggest that you contact www.bugaboo.com who will be able to assist you in purchasing these spares. If the problem is with the **** strap or shoulder harness parts, you may have to purchase a new seat fabric. I hope this helps.
9helpful
Evenflo aura travel system
I hope this information helps:
1) There are harness anchors (metal clips) located on the bottom of the seat. Push these up through the slot to the front of the seat on both sides. To do this, you will need to pull them toward you, and then turn the anchors to fit through the slots.
2) You should be able to remove the bottoms of the straps at this point. Remove them, then pull the tops of the straps through the slots. (You will need to remove the buckles during this process.)
3) Slide the straps through the slot you need for the correct harness height.
4) Replace the buckles in the correct positions.
5) Replace the bottoms of the straps into the harness anchors.
6) Push the harness anchors through the padding and back into the bottom of the seat. Clip into place.
Top Kelty Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Kelty Baby Gear Expert? Answer questions, earn points and help others
