It sounds like you may be experiencing issues with the LED lights that you installed in your Samsung 55-inch smart TV. The fact that the dark spot on the screen has moved to the left side and the lights are appearing at the bottom of the screen like Christmas tree lights is not normal behavior and could be caused by a number of factors.
Some potential causes for the issue could include:
- Incorrect installation: If the LED lights were not installed correctly, it could cause the issues you are experiencing. Make sure that the lights were installed according to the instructions provided by the manufacturer and the video you watched on YouTube.
- Damaged LED lights: The LED lights themselves may be damaged or malfunctioning, causing the issues you are experiencing. Try replacing the LED lights with a new set to see if this fixes the problem.
- Other issues with the TV: The issue could also be caused by a problem with the TV itself, such as a malfunctioning display or control board.
To troubleshoot the issue, you can try the steps listed above. If you are unable to fix the problem, it is recommended to contact Shop Jimmy or a TV repair technician for further assistance. They will have the necessary tools and expertise to properly diagnose and repair the issue.
