Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
I have a bissell proheat and it won't release the water/shampoo. We have replaced the pump, and it still doesn't work. What can I do?
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dhfjd
Posted on Sep 30, 2010
Directions on how to use the rug shampoo machine, bissell. the ones that come with the machine
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Nov 23, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
My bissell proheat shampoo machine won,t spray solution from the hand wand
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Aug 18, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Rollers don't turn and pump doesn't put out any shampoo or rinse water
You need to replace the Pump belt and the roller brush belt. You can get both belts and view the manual which has instructions here:
Bissell Proheat Replacement Belts and Manual
Nov 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell steam cleaner will not spray shampoo
My Bissell stops releasing shampoo when the handle is lacked upright, when there is no water in the tank (the most common cause of this issue), or when water is not flowing through the machine because the sprayers are clogged.
Make sure the shampoo container grommet is releasing properly when you press the trigger. To check this, remove the shampoo tank from the Bissell, stand over a sink, and use a finger to push up inside the grommet on the shampoo container, the part of it that mates with the rest of the Bissell. Shampoo should dribble out when you do this. If it won't, the grommet may be clogged.
May 29, 2009 | Bissell 7950 ProHeat Upright Wet/Dry...
NO WATER COMING OUT FOR SHAMPOOING /DUMPS WATER WHEN UPRIGHT
there is a belt inside that runs the pump to spray the water. I would take it in a have it replaced. Mine did the same exact thing.
May 25, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell proheat 1698 reassembly, smart mix piston, new pump?
heatman101
erqtr
Mar 01, 2009 | Bissell 1699 ProHeat Clear View Upright...
No water or shampoo releasing
Take off the 2 spray nozzles and blow thru them, they may be clogged. You ay also try running a mix of water and vinegar thru it to help clean out the lines. May have a bad pump.
May 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Wont release liquid or shampoo.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=601973
Won’t release liquid or shampoo.
Posted by lilmrsmcd on May 16, 2008
I have a Bissell Pro Head 2X Steam Cleaner Model # 9300-C
The little plug at the bottom of the bad for clean water came apart and would not let water out now won’t hold it in.
Inside is a little propeller a spring a washer and a little black plug. Flat on one side and beveled on the other. We have tried to put it back in various selection and cant fix it please help ASAP liquid bladder will not release water.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Bissell 9500 ProHeat 2X Clean Shot Upright. On the little black plug – they do wear out and need to replace it but use a genuine Bissell part when replacing the part other wise a replacement may not work. Q. #2 the little propeller spring usually is part of the solution tank and it is wise to replace the part with a new or a good used tank from Bissell, so check with your local factory authorized vac dealer that carries and services Bissell. I will give you the Bissell factory phone # listed below for further questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 16, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
135 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
