Question about Ruud Central System Air Conditioner
No air blowing inside the house thru vents;starts fine than stops
Have a 1994 Tempstar model # NPAHC36AK01; will turn on a/c and air will blow thru vents inside for awhile and then stop totally and of the unit continues to run with no air coming inside. The fan outside on top runs fine. Can some one help I live in florida and have MS so have to have a/c and have to try to fix myself due to short on money.
Thanks in advance
    Problem Solver:
  • 9 Answers
You are likely low on charge and the unit is freezing up. You need some with gauges to check. You should not try to run this unit until then or it will burn out the compressor.
Posted on Jul 18, 2009
Need list price for whole ac/heating unti. Bought system new, stored for several years. Dont want to take any losses parting out unit though. If you can find price for me Id be willing to help you if you still need it.
Posted on Dec 28, 2009
My 2002 trane XE 1200 gas &electric unit stopped blowing air
it may be the blower motor not working inside the house check the cap for the motor & the power to the motor
Apr 28, 2014 | Heating & Cooling
1999 z71 air conditioning randomly stops blowing
If the air stops blowing from the vents, the problem is with the blower motor. If it doesn't come on, try slapping the motor with your hand. If it starts when slapped, replace the motor.
Do It Yourself Diagnosis and Repair
Aug 14, 2017 | 1999 Chevrolet Silverado 1500
My 93 Grand Cherokee has a problem with "not" switching from blowing air down at ones feet to ones chest area. I know the fan is working fine, but it will only blow air thru the lower vents and...
  • Sounds like your Blend Door Actuator is malfunctioning. What that does is move an arm to open a door down on the blower motor to send the air into the passages you choose. If the Actuator goes bad or the plastic arm to the door snaps or breaks then you get air flow where ever it broke at and it won't change until you make that door function again. Please see the picture I uploaded so you can see what I am referring too.
  • The Blend Door itself were known for sticking too so you may want to investigate inside the heater box as well.
  • You will find the Actuator itself on the side of the blower motor housing.
  • Good luck to you and thank you for choosing FixYa.
Regards, Tony
Jun 13, 2011 | 1993 Jeep Grand Cherokee
HEater is heating outside but not blowing warm air thru the vents inside the house. May blow air for 10 mins but then stops. I have the temp. set at 76 degrees but it is 48 degrees in my house right now.
sounds like you may have some restriction in the heater or overtemp sensor is kicking out to soon, clean everything thourghly, check fan and oil bearing, check safety circuits in furnace wiring, refer to owners manual trouble shooting guide
Jan 30, 2010 | Goodman GMS90703BXA Heater
Tempstar Door model keeps overfilling
The sensor is a plastic pipe (vacume) / and a ajustable switch. The rise in water causes the air pressure in the pipe to increase and at the set level this stops the water inlet valve. You could disconnect the pipe and blow into it slowly and should hear the switch click. Most faults are the plastic sensor pipe blocked / obstructed and or the switch terminals (inside switch) burnt. This means that the switch must be replaced and should be set for the correct water inlet.
Jan 21, 2010 | Jackson 25 in. TempStar HH Free-standing...
Heater stopped blowing hot air this wonter
You need to check the heater core it has two hoses going to it feel of them if one is hot and the other cold heater core is stopped up replace it or flush it out if they are both hot it can be the switch or a vacuum line the vacuum line will be on the passenger side under the hood where the airconditioner hoses go in the body
Jan 21, 2010 | 1994 Chevrolet Camaro
1004 tempstar a/c air quits blowing into house
Possible fan motor problem. Bad capacitor or bad fan motro. Either way you ned to call a service tech. Russ
Jul 18, 2009 | Heating & Cooling
Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
many times when a unit has a defrost problem the coils freeze up and do not allow the fresh food side to cool properly...check for a build up of ice on the inside back wall of the freezer compartment. if there is a build up of ice, you have a defrost problem. Also, check to make sure the evaporator fan in the freezer is blowing the air into the fresh food side.
Dec 26, 2008 | KitchenAid KSRS25IL Side by Side...
Ruud Central System Air Conditioner Logo
548 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
