Question about Roper RAS8445KQ Top Load Washer
Washer won't start. water pours down sewer pipe
When I turn the washer on to wash, the machine continues to pour water through it without starting the wash. the water pours straight down the sewer pipe
    President:
  • 1,136 Answers
Hi, If the water is going out the drain hose, raise the drain hose so that its highest point is as high as the top of the washer. This should take care of the issue. If the water is coming out of the bottom of the machine, tip it back against the wall and look under the washer to see if a hose has broke or came loose.
If I can assist you further, please let me know.
Vic
Posted on Jul 18, 2009
F18 error code on Bosch Exxcel washer/dryer, and water pouring out the bottom - any ideas on how to fix? Filter is clean.
Sump hose has fallen off Unplug tilt machine back have a look underside to check also could be the soap dispenser hose Hole in it.This rubs away on side of machine 5yrs old.
Sep 13, 2017 | Bosch Logixx WFT 2806 Front Load...
This might help you with the pump its on a bosch Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2013 | Bosch Logixx WFT 2806 Front Load...
I have removed my washing machine and water is pouring out under the sink
Have you turned off the small lever on the pipe under you're sink that supplies you're washing machine with it's water
Mar 07, 2012 | Washing Machines
Sewer smell when I use the front load washer
try rid-x see if that helps pour down drain pipe for washer then add water you may also want to pour rid-x through toilet as well and bleach out washer
Dec 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Water continuously runs and cycle won't start. The washer tub doesn't seem to be filling with any water.
Probably a syphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from comming out the drain pipe , go to home depot or an appliance parts house , and get a syphon break . When a washer fills , but water level doesn't rise in the machine , it's being sucked out by syphoning thru your sewer pipe .
Aug 08, 2009 | GE WVSR1060A Top Load Washer
Leaking Water
try pouring boiling water down soap draw possible blockage due to cheap wash powder take off lid and massage down pipe then put on wash with no clothing
Nov 10, 2008 | Samsung WF337AA Front Load Washer
Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
Mar 17, 2008 | Asko W6441 Front Load Washer
Roper RAS8445KQ Top Load Washer Logo
90 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
