Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
We keep getting code 92 (high salt). There water
We keep getting code 92 (high salt). There water is not salty at all and we've cleaned the sensors in the filter. Any ideas what's wrong?
    Sniper:
  • 86 Answers
From the FAQ, What should I do if code 92 appears?
There are several things you may need to check and do:
- Test the salt level first with Test Kit, drain approximately 20% of the pool water and refill with fresh water.
- If code 92 still appears despite the above step, there might be a electrolytic cell failure. Please contact Intex Service Center, and replace the cell if needed.
Posted on Jul 18, 2009
High copper, High alkalinity, No chlorine & salty water
call in a pool expert to help you set up the system properly and to check the chlorinator
from your statement you are making things worse by not fixing the problem
Mar 18, 2017 | Intex Automatic Salt Water System for ...
Cloudy/salty water, stuck bypass valve
water in your salt store is normall. it is commonly called brine. this is purely a cleaning agent of your water softener to regenerate the media. you do not drink this water nor does your water pass through this. it is only pulled through into the unit when regenerating.ie. this piston is in a position which allows the water to flow through a v enturie pulling the salt. water will sit in the brine tank always to be ready for the next generation and to be at the correct brine dilution so it's important to maintain the salt level above the water level. cloudy water is nirmally air bubbles which should settle out within a couple of minutes . if it tastes salty I suspect your regeneration waste water is contaminating your supply feed. like seeping back into well or tank .
Apr 18, 2017 | Water Dispensing & Filtration
When i change the pump filter let run for a while code 92 sets
2 reasons for this code...
1st... High salt level... You must check and should be between 2500 to 3000 PPM.. If higher, drain some water and fill with fresh water and re-check..
2nd... If salt level is okay, your electrolytic cell may have calcium buildup and must be cleaned and flushed.. Cap one end of the cell and fill with vinegar and soak for 6hrs+. Flush with water pressure until blades inside are clean and free of the "White Flaky" stuff...
Hope this helps you???
Good luck...
Aug 08, 2011 | Intex Automatic Salt Water System for ...
My water is cloudy and says salt level low.....it seems salty enough as I can feel and taste it. Is there chemicals I am supposed to be adding or does this system keep it clean all alone just by adding...
While your problems are likely greater than just the salt content in the water I can tell you that if you feel, or more importantly can taste the salt in the water your salt level is WAY TO HIGH, not low. Have the salt level confirmed with an independent test either at a pool store or using a salt tester.
John
Jul 21, 2011 | Intex Automatic Salt Water System for ...
KEEP GETTING A CODE 91 LOW SALT?
As mentioned in many of my post's, you can not just go by the reccomended amount of salt in the owners manual.
You must get salt test strips that read in #'s not colors and get your salt as close to 3000ppm as possible lower than 2800 and you will not generate enough chlorine or trigger low salt alarms
any higher than 3500ppm and you could get cloudy, or trigger high salt alarm
the water will also taste too salty when adding salt dont forget to stir up the water and filter only for at least 12 hours before trying to generate salt
Longer if you ad a lot of salt like 75 lbs or so
Jul 19, 2010 | Intex Automatic Salt Water System for ...
My salt light won't stop flashing even though its full of salt. Its a Hotpoint FDW60. Ive tried turning off and an at the mains.
I think I have the answer.
On Yahoo Answers Blue Rizla Girl put up the idea that the sensor is some form of hydrometer. (i.e. floats in salty water sinks if not salty enough)
Based on this thought I postulated that the sensor is some form of hydrometer float in a tube with perhaps an optical sensor.
If this is correct why is it not working?
Is it because the float is stuck at the bottom of the tube, perhaps by some food debris? If so how can we fix it?
This is what I did on my Hotpoint FWD60:-
I took the salt filler cap off. There was no salt in the reservoir as it has been a problem for months, and I was only refilling it when dishes were not coming clean.
I poured 2 litres of hot water into the salt reservoir.
I then put the empty machine on the intensive 65 degree wash, half load and with the reservoir cap still OFF.
When finished I filled up with salt and HEY PRESTO the salt light is OFF!!!!
Just hope it stays that way until the reservoir really needs refilling.
While I was down on my hands and knees I took the opportunity to clean the filters in the sump. They do get full of bits!
I also flushed the sump by dashing a couple of cups of hot water into it and then bailing it out with a small yoghurt pot. I repeated this until the water in the yoghurt pot and the sump no longer had any signs of bits in them. (Dashing = vigorously pour)
I was amazed at how many bits I got out, especially considering I had given the machine a good clean in the past 6 weeks.
I even got part of a paper label!
So there we have it, try it out and report back.
AcmeUK
Oct 19, 2009 | Hotpoint 24 in. FDW60 Free-standing...
High ph, algea, salty taste
You are going to need to buy chemicals anyway (acid for sure and probably algaecide) so find a good pool store tech and have them test your water and recommend the proper doses.
In summary though, you should not taste the salt in the pool and being able to means the salt content is to high. Chlorine generators will not work if the salt is to high and the fix is to drain water and dilute the remaining water until the salt content is no higher than max. No chlorine could explain the algae.
Generators also cause the pH to rise over time so you will need to keep acid on hand to counteract that.
Jul 05, 2009 | Intex Automatic Salt Water System for ...
My saltwater pool tastes very salty, but my intex saltwater pump keeps saying low salt. I have to clean the cell everyday or it will not operate properly because the cell gets covered with white buildup...
Your salt is way to high if you can taste it. You will need to dilute with fresh water until you get the salt back down and then clean the cell for continued use.
Jun 25, 2009 | Intex Automatic Salt Water System for ...
Code 93 saltwater system
Hi, Code 93 is telling you that the system is done running, did you mean to say it said 92? That code would be for too much salt. If indeed it is a Code 92 you are getting, give Intex a call, or email. I have found their website to be very helpful, they have a F&Q's area. Good luck!
Jun 15, 2009 | Intex Automatic Salt Water System for ...
Matsui mf160 dishwasher salt indicator will no go out
AcmeUK
Apr 20, 2009 | Dishwashers
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
1,463 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
