Question about Roper RS22AQXKQ Side by Side Refrigerator
Roper rs25agxn side by side refridge
I need wiring diagram for please submit
  • 290 Answers
Here is a link to the page at servicematters.com
http://www.servicematters.com/docs/wiring/wiring_main.htm
Post back if you need further help.
Posted on Nov 19, 2007
  • Michael  Lindley
    Michael Lindley Nov 22, 2007
    Just wanted to follow up on your fridge and make sure the link I gave you was correct.
    Thanks/Mike
Freezer works, refridge works gets cold but sometimes power goes out on refridge side and then tries to cycle on. if i unplug unit from wall and reboot then it will work is there a sensor for too low...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 20, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
My pully is laying in the bottom of my dryer. I need a diagram to know where it is to go. model number RES6745PQO
Many Roper Dryers use Whirlpool parts. Have a look at these two diagrams to see if yours looks the same:
If this helped, please rate it "4 thumbs up". Thanks!
Aug 01, 2011 | Roper Dryers
I need a wiring diagram for a Roper Dryer REX3514PQ0. Is ther e any place on the web that this can be obtained?
Many of the appliance parts websites also have wiring diagrams..
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Jan 05, 2011 | Roper Dryers
I have a Roper side by side refridge-freezer. We smelled an electrical smell last night. Today the freezer/icemaker thawed out and the refridge also did not cool. I have pulled the back off and checked...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 04, 2011 | Roper Refrigerators
Upgrade to 4-Wire/Prong Dryer Cord
Hi ,, here are typical diagrams for the 3 prong and 4 prong connections for clothes dryers ..
if you need more description , get back
Please vote !!
May 30, 2010 | Roper REX3614KW Electric Dryer
Need a wireing diagram for whirlpool refridge ET18PKXWN10
The diagram is usually located in a pouch you can see when you remove the bottom vent. It has all sorts of service information, including a wiring diagram. Otherwise whirpool.com may have it.
Aug 25, 2009 | Refrigerators
Ice maker is not making ice...no water to tray, but.ice maker motor works
there may be a sensor in the bin where the ice cubes drop into. It tells the ice maker when the bin is full so it stops making ice. Check to see if that sensor got bumped or moved or needs to be reset
Jul 07, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Ice maker not making ice
The fill tube could be frozen. Gently use a hairdryer. If not you have to check the fill valve coil in the back to see if it's getting power. If it is replace the valve. if not check wiring connections etc. If there's no power out of the Im to the valve, replace the IM
Problems with water are most common tho. Please rate this
Jan 23, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Roper RS22AQXKQ Side by Side Refrigerator Logo
114 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
