Question about Dryers
Inside of drum baffles coming loose on maytag neptune dryer
  • 55 Answers
Hello.
Remove the door and the plastic pieces on the opposite side. Take the front panel off. There will be one metal bracket on each side holding the top panel down. Remove those brackets and lift the top. Turn the drum where the loose baffle is up top and tighten loose screws or replace missing ones.
Posted on Jul 23, 2009
Maytag neptune dryer one of the dividers the screws came loose how can I fix this without calling for service
You are probably referring to the drum baffles. The baffles securing screws can be retightened by raising the top which requires the removal of the front panel. Click on the link below for the detailed steps.
Retightening the Baffle Screws on Maytag Neptune Dryers
Jan 24, 2011 | Dryers
The beater bar in my Neptune dryer modeL # MED5500AYW has come off and needs to be replaced.
It sounds like you are referring to the drum baffles when you say "beater bar". If that is so, you need to remove the front panel then raise the top cover to access the baffles mounting screws outside the drum. Below is the link to the procedure I posted previously.
Maytag Neptune Dryer Front Panel and Top Cover Removal
Sep 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer making banging noise on each rotation on the left side facing the front. its almost like a thumping noise what do i need to do please?
The drum baffle screw has unscrewed itself and the head is thumping against the inside top panel. Pull door, lift lid, rotate drum to find screw sticking out and tighten.
Aug 03, 2010 | Maytag MDE5500AYW Electric Dryer
We have a neptune front dryer and a baffle came loose inside the drum. How do we repair it
an easy way of reinstalling the baffle is remove the top cover or rather flip the cover upward this will show you the dryer drum in which u can spin the drum to the proper spot where u can retighten the screws that hold the baffle on hope this helps
Jun 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
As dryer rotates, with clothes drying, it sounds like loose pocket change is loose in between the two tubs.........help!
the change gets caught in the three baffles that are attached to the drum.unplug the dryer,open the door and remove the two screws that hold the in place,remove the door,then remove the other two screws opposite the door screws and pull the front panel off.rotate the drum so one of the baffles are down in the right hand corner so you can get at the screws that hold the baffles onto the drum.try loosening the screws but you might have to remove the baffles to get to the change.let me know how you make out
Apr 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I know that I am asking this for the third time; however, on the other two I forgot to notate the make and model. Again, after I opened the top of the dryer, there were no coins, it seems to be the screws...
If the screws holding the baffles just came out of the baffles or if the baffle broke they can be reinstalled. If the screws have ripped though the drum, the drum will need to be replaced. The screw part number is 33002973. The short baffle part number is 33001755. The tall baffle part number is 33002032. If you need the complete drum it is part number 33001889. Below are the instructions on how to replace the drum. Parts can be ordered from this link.
below is a link to the service manual for the info u need to take aprt or replace the dryer drum on a Maytag Neptune, I suggest u print it and then enlarge it if u can read it.
http://media.fotki.com/1_p,swdbrqkqdgssrtkxgtqsskgwtqkq,vi/stkwfgbrgxkgtddqfqs/1/1303472/5961857/image7951020310251998097img-or.gif
Apr 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
BAFFLE INSIDE THE DRUM IS LOOSE. HOW DO I TAKE FRONT OF CABINET OFF SO THAT I CAN GET TO OUTSIDE OF DRUM TO TIGHTEN SCREWS HOLDING BAFFLE?
Open the front door where you load the machine.
Look towards the top where the door normaly closes, there ususualy two screws that you can unscrew there.
Once loose the top pannel should come off, which allowes you to remove the front panel with 2 screws as well.
Nov 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer
Hi thanks for the question. the top of the dryer comes off. revealing the screws that hold the baffles in place . re- install the baffle, and the top. thanks the appliance doc.
Oct 06, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Neptune gas dryer
Did you check the baffles( fins inside the drum) loose of broken.
Can you turn it by hand and hear the same sound? does it turn easy or very hard...let me know I can help
krazytech
Mar 23, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
362 people viewed this question
Top Dryers Experts
