Question about Motorola MC75
I cannot get my phones volume to a good level when I am using my headset I tried it with a different phone and it is fine so it is my mc75. The volume is fine without the headset. Any suggestions?
    New Friend:
  • 42 Answers
Download this link and it will walk you through what headsets work best adn how to set up the volume
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=10307703apdf&sliceId=&dialogID=166010969&stateId=0%200%2019493076
Posted on Mar 26, 2010
My headset stopped playing volume, how do I get it reset?
Try another headset first to isolate the problem. If the other headset is ok then I would check the in line volume control if fitted or it could be the cable is broken at the plug end or the headset end. if the second headset does not work either then check volume levels on phone. does phone speaker work ok. Can also be headset socket on phone worn out ?!
Feb 04, 2015 | ZTE Cell Phones
Low volume on headset
Press the volume up button.
When the phone is idle, the volume with set teh ringing volume.
When the phone is in speaker phone mode, the volume adjusts the speaker level.
When in headset mode, the volume adjusts the headset volume....
Dec 06, 2012 | Avaya 9608
Sound level is inconsistant in headset. Unable to adjust volume with "rocker" buttons.
The Plantronics 510s system includes the 500A base and the Voyager 510 Bluetooth headset. Number "one" on the lower back of the 500A base is the loudest setting for your listening volume, I would also check to make sure that the compatibility setting on the left side of the 500A base is set to "one", so the number one should be lined up in the 3 o'clock position (which would also be lined up with the ridged area to the right). Number one compatibility setting is the most common setting for most phones. You can also try using the headset with a cell phone to see if the volume adjusts or not, if it still doesn't work properly, maybe the headset is just wearing out. Here is the link for the replacement headset:
http://www.headsetsdirect.com/84321-01-510-replacement-headset.html
Good luck from Headsets Direct - 800-914-7996.
Aug 24, 2011 | Plantronics Voyager 500A Headset
We are using the Plantronics CS55 wireless headsets. The users are complaining that the '3-beep' incoming call alert tones are too loud. We have tried to adjust this tone level by manipulating...
Lowering the ring volume on the phone only decreases the sensitivity of the lifter, which generates the signal to the headset. The signal volume between the two is preset and cannot be adjusted.
Good luck from Headsets Direct!
Jul 20, 2011 | Plantronics CS55 Wireless Headset
I have the Plantronics S11 headset and I can hear callers, but they can't hear me, I need to know what to do. The phone is working fine and everything is all set up correctly as far as I can tell.
There are a couple of basic things to check first. You want to make sure the mute is turned off and your outgoing (mic) volume is loud enough (there is the speak level switch on the side and the speak volume control on top). Also, you want to make sure it is connected through the handset jack on the phone (generally it will not work through the headset jack on the phone). Finally you want to make sure it's configured right (scale located on the side).
Good Luck from Headsets Direct!
Jul 04, 2011 | Plantronics S11 Headset
How do I control the volume on my Plantronics 220? Is the rocker switch on the side the volume?
There are two ways you can control volume on the headset. One is through the volume controls on the cell phone and second, through the volume switch located on the side of the headsets. There are five levels of volume on the headset.
Jun 23, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Connection problem to phone light turns green instead of blue
Try resetting your headset by pressing power key and volume up key, until the LED flickers in different seqence. after a while try connecting with your device. it should work.
May 24, 2010 | Jabra BT350 Bluetooth Headset Headset
Plantronics CS55. When using the wireless headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Jul 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Outside caller hears themselves in an echo
Jan 23, 2009 | Plantronics CS55 Wireless Headset
Earpiece volume on my motorola h700 is low.
while talking to your party try the volume on your phone, it should come up as bluetooth or earpiece volume if it does just turn it up and dont forget to hit the set button. good luck m.m. p.s. some times the volume isnt set at the factory. im fighting that problem now on two of my seven h-700s. this may be a solution it may not im letting you know my experiance as best as i can.m.m.
Jan 22, 2009 | Motorola Mobility H700 Wireless Headset
Motorola MC75 Logo
125 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
