Question about GE Profile Advantium SCA2001KSS Stainless Steel Electric Single Oven
The rotary selector knob on advantium oven is not working
The rotary selector knob on our GE Advantium oven (SCA2001KSS) is not functioning. Press select works but rotational selection does not. Any ideas how to fix?
I am not a tech and pretty clueless. However, I previously removed and took the panel apart and checked for resistances, etc. trying to find a fault. I did not find a thing but once reassembled the oven worked properly for several months. Once the problem reoccured I tried this again but it did not work. FWIW, we are in Tampa Bay area, which is the lightning capital of the world.
3 Suggested Answers
SOURCE: ge profile advantium 120, scb1001 oven, display panel out
My GE Profile Advantium120 interior lighting it out .What do i do to replace these bulbs.
Posted on Apr 06, 2009
Turned off breaker for 30 seconds. Display returned.
Posted on Jan 20, 2010
How do I turn the Miele oven on? Model is H6260BP
To turn on the oven, press the recessed On/Off button on the left below the rotary selector knob. Make sure that the system lock is off. (The display will show S 1 if it is on.) Press and release the function selector and rotary selector knobs if they are retracted. Rotate the function selector to the desired function icon (line up the dot). Then turn the selector knob to select the oven temperature. Press OK to start cooking.
Miele has the manual for the H 6260 BP oven on the product site on the Downloads tab: https://www.miele.com.au/domestic/ovens-1451.htm?mat=09514470&name=H_6260_BP . The direct link to the manual is https://www.miele.com.au/pmedia/ZGA/TX3587/10108150-000-01_10108150-01.pdf . See page 21 for a picture of the oven controls.
I hope this helps.
Oct 04, 2016 | Miele Ovens
My GE Profile Advantium Microwave Oven runs (and heats) continuously. The only way to stop it from running is to open the door.
Hi
Sounds like a defective door interlock switch or a broken switch mount. If it's not a problem with the door switch or door switch mount you will need to replace the magnetron and the touch pad as well.This will fix your issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 27, 2011 | GE SCB2001FSS Advantium Electric Single...
My scb2001kss ge advantium no longer heats. it turns on and everything else works, but heat
check breakers for oven one side could of tripped if everything else works but the heat this is a normal problem the only other thing could be is that the controles are not working
Jan 26, 2010 | GE Profile Advantium SCB2001KSS Stainless...
GE Advantium SCA1000DBB03 handle replacement
open door look at side there some are some screws remove them the outer door part will come off now don t be afraid to use screwdriver to help take it off good luck later
Apr 01, 2009 | GE SCA2001FSS Advantium Electric Single...
Microwave
Hi my GE Advantium oven is displaying an error message and beeping. The Error is F3. Could you please help me with this.
Nov 02, 2008 | GE ZSC2001FSS Advantium Electric Single...
GE Advantium Microwave portion not working
There is a fuse for the Hi voltage transformer and the magnetron tube. You have to take the cover off to access the fuse.
Sep 02, 2017 | GE ZSC2001FSS Advantium Electric Single...
Ge profile advantium 120, scb1001 oven, display panel out
Jun 29, 2008 | GE ZSC2001FSS Advantium Electric Single...
GE Profile Advantium oven (stainless steel)
spray a little oven cleaner on a wet rag and wipe. Rinse really well afterwards. Do not spray directly in oven. It could get in the holes.
Jun 10, 2008 | GE Profile Advantium SCB2001KSS Stainless...
Can't make my oven work after a power loss - GE Profile Advantium
check voltage to oven. if thats ok your control board may be shot.
Feb 01, 2007 | GE Profile Advantium SCB2001KSS Stainless...
GE Profile Advantium SCA2001KSS Stainless Steel Electric Single Oven Logo
164 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
