Question about Altec Lansing ACS 52 Computer Speakers
What is the voltage transformer for an altec acs53
What is the output voltage for the transformer for an altec acs53
4 Suggested Answers
Eriez
  • 14 Answers
SOURCE: burned amplfier ic
A very simple solution to that , if you have no service manual of your gadget,,try google and search for your model or specify the part ,,eg.. ic , (how mny pins ?) , google could even give you the pin configurations. I already tried this ,,,,, dont hesitate,,nothing will be nil anyway....Second option, try to visit RadioShacks in your area and bring your speakers for better check up or they could give you another substitute part.....good luck...
Posted on Apr 05, 2008
  • 6 Answers
SOURCE: Transformer blew on Hk395 speaker sysytem
I think I remember it being in the 12-24VAC range. If you are still interested I will open mine up and measure it.
Posted on Aug 16, 2009
SuperTech-11
  • 1591 Answers
SOURCE: Hi there My Altec Lansing 121i
This is one of those "it's cheaper to replace the speakers" scenarios as these units can be had for $25 new, and for even less on E-Bay.
Posted on Mar 27, 2011
Power trafo altec lansing atp3
Is the label missing? All the information is printed on a label or stamped into the plastic housing. Have you opened it? Many have an internal fuse you can replace.
Jul 15, 2014 | Audio Players & Recorders
How can my laptop charger fit to computer speaker?
Please do not modify your laptop charger to power your speakers. The laptop charger probably has too high a voltage and amperage output. (USB chargers don't provide a large enough output.) The Altec Lansing ACS40 speakers need a 15V 900 mA power transformer; the coaxial power connector has the positive voltage on the center pin. The model number on the transformer is 4815090R3CT . This is available through Amazon.com and other vendors. One vendor is http://www.emtcompany.com/altec-lansing-4815090r3cac-power-supply-charger-adapter/1010666.html .
I hope this helps.
Jun 03, 2014 | Altec Lansing Audio Players & Recorders
The transformer of my sub-woofer is burnt. When i take it to the repair shop, they say that the transformer is not available. I badly need to fix the speaker as i love them very much and the new ones are...
Sub woofers have small amplifiers , not transformers. The amplifier is removable and replaceable. The The overall size and the output wattage are the spec's you need . The output wattage is on the label which is attached somewhere on the speaker. You do NOT need to replace the amp with the Altec Lansing brand. Have you contacted Altec Lansing to purchase a replacement Amp? That's where I would start. If they cannot help you I would Google replacement amp sub-woofer, Altec Lansing model MX5021.
good luck
Apr 15, 2011 | Altec Lansing MX5021 System
Hi there My Altec Lansing 121i power transformer is spoilt. I would like to replace the same. What are the voltage ratings of the transformer Thanking you Vivek
Mar 27, 2011 | Altec Lansing 121i Computer Speakers
Hello. I have the altec Lansing acs40speakers but no power supply. What voltage do these need?
Class 2 transformer
Model: 4815090r3ct
Input 120vAC
Output: 15 vDC, 900mA
Center is positive, outer is negative.
Dec 04, 2010 | Altec Lansing Multimedia Computer Speakers
No power in my altec lansing S100 121i 2.1 speakers
troubleshoot the transformer and try to replace the Opamp (UTC458) on the circuit board. the Opamp might be broken and shorting the circuit and fry your transformer. goodluck.
Jun 26, 2010 | Altec Lansing 121i Computer Speakers
Step up transformer for altec lansing atp3 that runs on 220 volts
What voltage are you stepping up to?
Does the unit run off a seperate PSU/Transformer.
Can you check your info please.
Jan 19, 2010 | Altec Lansing ATP 3W Computer Speakers
Power transformer has no output i would like to know the specs of the power transformer thanks.
Should be printed or etched on the bottom of the transformer.
If not, take it to the Radio Shack and have then ID it for you
Nov 03, 2009 | Altec Lansing ATP 3W Computer Speakers
Burned amplfier ic
Apr 04, 2008 | Altec Lansing ACS 52 Computer Speakers
284 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
